Hitec Spectra Module teething problems
Old 06-14-2011, 12:44 AM
vasek
vasek's Avatar
Default Hitec Spectra Module teething problems
Good news i have received my Hitec module with two 9ch Rx.
I'm trying to figure out the basics. I have bound the Rx successfully, but when I take the Binding plug out, the system doesn't work. It works fine with the plug in the SPC slot.
I'm used to Spektrum, so I assume what looks like the binding plug in Hitec Rx (SPC port) has to be taken out prior to use. Am I correct? There's NO mention of the binding plug in the illustrations that came with the module.
Can someone tell me the basics please?
I appreciate your help as I am a little dyslectic (really) and sometimes miss the obvious.
V.
Old 06-14-2011, 02:45 AM
JIMF14D
Default RE: Hitec Spectra Module teething problems
It is not a bind plug! It is a power jumper. If you remove it you remove power from the receiver. Hitec does not use a binding plug. There is a bind button on the RX. That SPC jumper is removed if you want to run the Rx from a seperate battery up to 30+ volts.
Read your manual.
Good luck
Old 06-14-2011, 02:47 AM
A.T.
ORIGINAL: vasek Good news i have received my Hitec module with two 9ch Rx.
I'm trying to figure out the basics. I have bound the Rx successfully, but when I take the Binding plug out, the system doesn't work. It works fine with the plug in the SPC slot. I'm used to Spektrum, so I assume what looks like the binding plug in Hitec Rx (SPC port) has to be taken out prior to use. Am I correct? There's NO mention of the binding plug in the illustrations that came with the module. Can someone tell me the basics please?
I appreciate your help as I am a little dyslectic (really) and sometimes miss the obvious. Thanks,
The Optima do not use "Binding Plugs"
The blanking plug in the SPC port must be inserted if no battery lead is inserted, refer detail and pictures under:.
Optima Transceiver (RX) - SPC - SPC connection & Lead Detailed plus Optima Current Draw/Amps - NB: View warning Video re use of balance taps.
Optima Transceiver & Minima (RX) - Voltage Input Limits.
AFHSS - ID_Setup (also known as Binding or Linking) & Range Test Procedure Aurora 9, Spectra 2.4Ghz Module <> Optima Receiver.
ex Hitec USA Support Forum Sticky:
Aurora 9, Spectra Modules & Optima Transceivers
- FAQ & Undocumented Features
- Mixes, Setups,Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Old 06-14-2011, 06:43 AM
vasek
vasek's Avatar
Thanks Alan, it makes sense to me now!
Jim, I wish I had a manual
The module came with a little pamphlet, no mention of the "plug". That's why I'm on here with silly questions
Cheers,
V.
Old 06-15-2011, 12:36 AM
4*60
My Feedback: (41)
Do a search and you will find a manual.
http://www.troybuiltmodels.com/ns/ma...679_Manual.pdf
Old 06-15-2011, 01:33 AM
A.T.
ORIGINAL: vasek Thanks Alan, it makes sense to me now! Jim, I wish I had a manual
The module came with a little pamphlet, no mention of the "plug". That's why I'm on here with silly questions Cheers, V.
All the manuals and more available at
Hitec Product Support - Manuals
and more under Hitec USA Support Forum Sticky:
Aurora 9, Spectra Modules & Optima Transceivers - FAQ & Undocumented Features,
- please readfor reference of the various groupings.
Alan T.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
