Crystal Change
Old 06-14-2011, 05:07 AM
partzee
Default Crystal Change
Is it a simple process to change the crystal in a JR PCM 9 receiver?I don't want to open the case until I know.
Tks,partzee
Old 06-14-2011, 05:14 AM
BuschBarber
Default RE: Crystal Change
ORIGINAL: partzee
Tks,partzee
If you have the correct Crystal, it is very simple. If you purchase the RS2000 receiver, it is Synthesized. You turn on the Tx, press the button on the Rx, and the Rx automatically switches to the same frequency the Tx is on.
Old 06-14-2011, 05:20 AM
partzee
This receiver is old,1995 and I just want to change freq.do I just open the case and remove /replace it?
Tks,partzee
Old 06-14-2011, 05:30 AM
BuschBarber
ORIGINAL: partzee
Tks,partzee
The Crystal should have two pins extending from the bottom that plug into a socket in the receiver. You should be able to pull the old Crystal out and plug the new one in. If the crystal is soldered in, you will probably have to send the receiver in.
I had several JR 549 and 649 receivers but I never had to replace the Crystal. On my Futaba and Hitec receivers, the Crystal Socket was external. You did not have to open the case to Install or Remove the Crystal.
Old 06-14-2011, 05:33 AM
partzee
Many thanks,partzee
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
