SPCM rx antenna question
Old 06-15-2011, 08:36 AM
JCFLYR
Default SPCM rx antenna question
Hey guyz, I'm old school flying and still using spcm rxs. The old saying was the antenna had to stick out of the plane to get a good signal. At least this was true with fm rxs. My 50cc extra has a guide tube for the antenna but no exit hole out of the back or bottom of the plane. With spcm, does the antenna need to stick out of the plane? Thanks for any advise. John
Old 06-15-2011, 08:58 AM
BarracudaHockey
BarracudaHockey's Avatar
Default RE: SPCM rx antenna question
Well Spcm, PCM or PPM are all pretty much the same in that regard.
As long as there's no carbon fiber back there it should work fine. I ran internal antennas on 72mhz on several models.
Do a good range check, with the engine off and on, at different aspect angles around the plane.
Old 06-15-2011, 11:51 AM
JCFLYR
Thanks for that.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
