Travel-size, compact, portable transmitter (TX)
Old 06-15-2011, 08:44 AM
IL2windhawk
Default Travel-size, compact, portable transmitter (TX)
Does anybody have a few recommendations for a compact-size transmitter? I'm looking for something I could easily fit in a small backpack for day hikes to use with my small gliders. My full-size transmitters takes up too much room, and they are easy to damage on hiking trips. For that reason, cheaper is better, but I'm not opposed to spending a little bit as long as it's a compact design that would fit in a small box. I would look at 2.4 or FM versions.
Thanks.
Old 06-15-2011, 01:13 PM
Rafael23cc
Rafael23cc's Avatar
Default RE: Travel-size, compact, portable transmitter (TX)
Other than the trasmitters included with some toys sold a department stores, I do not know of any manufacturer that builds tranmitters smaller than the standard size. I know of a few manufacturers that build even bigger transmitters, but not smaller.
How small are you looking at? I've been able to put my 9 channel transmitter in backpacks and carry-bags without a problem of course being careful to protect the switches and gimbals. Maybe you can find the foam insert that your radio came in from the factory and make a protective case of it to be able to drop it in a backpack with little worry.
Rafael
Old 06-15-2011, 01:21 PM
fizzwater2
My Feedback: (60)
The new Futaba 8FG is a fairly small transmitter. Not necessarily "mini" but smaller than some.
Old 06-15-2011, 06:46 PM
baronbrian
My Feedback: (13)
baronbrian's Avatar
how many channels are you looking for? for small gliders in the 3 channel range Hitec has some radios with a single gimbal for the right side. http://hitecrcd.com/products/aircraf...-fm-72mhz.html for a "full house"radio maybe you could strip an old 4 or 6 channel radio and fit the stuf into a smaller case.
Old 06-16-2011, 05:16 AM
AndyKunz
Spektrum DX4e is pretty small but still big enough to not be a "toy." It works with all the Horizon (Parkzone, E-Flite, Blade) micro planes and heli's, and is full-range so you could use it to fly larger planes at your park or club field.
http://www.horizonhobby.com/Products...rodID=SPMR4400
Andy
Disclaimer: I work for Spektrum
Old 06-17-2011, 12:36 PM
IL2windhawk
Thanks for the tips~!
Old 06-19-2011, 07:18 PM
swede47
http://www.rshobbies.com/proddetail.asp?prod=GWSRCS057A
Old 07-06-2011, 11:55 AM
IL2windhawk
OK - i have a new requirement for my travel-size transmitter. After some consideration, I decided that all the above examples are great except for one thing: no model memory! If I have to buy 3 or 4 of these transmitters, then I'm spending the same $$$ as if I bought one fairly nice TX.
It looks like there is a void in the market (hint, hint, hint...!)
Thanks everyone for the suggestions
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
