Airtronics Servos to Futaba FASST Rx
Old 06-17-2011, 08:33 AM
jstrach
jstrach's Avatar
Default Airtronics Servos to Futaba FASST Rx
Good morning everyone. I'm attempting to convert my 20 yr old GPSportster 40 over to my Futaba 7Cradio. The old Airtronics Rx and servos with Sanwa connectors are currently in the plane, but my new R617FS Futaba Rx is 10g whereas the old Airtronics Rx is 41g (1/4 the weight) PLUSit's 2.4 so that's favorable as well... BUT,here's something I've never had to deal with before... the connector on the old Airtronics servos do not work with the new Rx. I'm assuming the three wires are in different order (i.e. Airtronics S3004 have a red wire at pin #3 whereas the Futaba should be pin #2 - I think).
Anyone have to deal with this?(Obviously some people have... that's why I'm writing in the forum!) Can you offer some instruction or advice? I also notice these old Sanwa connectors are too "thick" and I guess I need to order some Futaba plugs to convert the servos otherwise they don't fit in the Rx. I reckon' Tower Hobbies sells these connectors? I'll go look while waiting for some feedback on this thread...
Thanks in advance for the words of advice....
Old 06-17-2011, 09:57 AM
ArchNemesis
Default RE: Airtronics Servos to Futaba FASST Rx
Hi Jerome,
A few thoughts.   Changing the servo connectors is no big deal, you can either put new connectors on or get the little 3" conversion connector cables.  But if those servos are the old style plug, they're at least 14 yrs old.  The last servos sold that way are back from 1997.  You'll spend more time messing around with the connectors than you would picking up some new servos.  I can't tell from the photo what servos those are, but servo technology has come a long way to where even the inexpensive servos today are stronger, faster and center better than all but the very top of the line servos from back then.
Also, in this day of all digital, not all of the older analog servos are compatible with 2.4Ghz systems (regardless of brand).  So that's something to be aware of.
As for the wiring, it's a simple change.   Swap the red and black from the old connectors.  The current servos (all brands are the same now) have the red positive lead in the middle and the black neutral on the outside.
Hope this helps!
Old 06-17-2011, 10:16 AM
jstrach
jstrach's Avatar
ORIGINAL: ArchNemesis
Right, Irecognize that picking up some new servos is "easy" - but it's at a minimum $65 for four servos. The connectors are $10 from Tower Hobbies.
This would be the deal breaker for sure, then... but I won't know until I get the connectors set up.
There are three wires coming from Airtronics servos; whereas there are two on my Futaba servos. Not sure what the third wire is. Ihave one black with red stripe; then two solid black wires on the Airtronics servos. On the Futaba, there usually is only a red and black - but then sometimes there's a white wire....?
[/quote]
Old 06-17-2011, 10:35 AM
ArchNemesis
There has to be 3 wires.  Even on the Futaba's.  The White wire on the Futaba is the signal wire. The red and black is simply power.  The only futaba wire without a white wire should be the one from the switch harness that's supplying only power to the Rx.
On the old ATX servos, the wiring was Red, Black, Black (nice visual use of color eh??)  Red - Pos, Black - Neg, and Black - Signal.
What servos are they?  94???
Old 06-17-2011, 02:23 PM
jstrach
jstrach's Avatar
Iguess if I thought about what I was saying a little longer, I would have realized I was thinking about the power switch wires only having two while all the servos having three wires.
Iwill include a close-up picture of the old servos - which must be about 20 years old (circa 1991-1993). Model 94102
UPDATE:added a fun Rx comparison pic too.
ID:	1624525   Click image for larger version
Old 06-17-2011, 05:00 PM
pilotpete2
pilotpete2's Avatar
Hi Jerome,
If you do update the connectors on those old 94102 servos they'll work fine with your R617FS receiver. My old 4 Star 60 beater has five of them connected to an R617FS, they'll work fine and last a long time
If you're comfortable with splicing on new servo wires with the proper connecters, just splice the white (signal) wire of the new connector to the outer black wire of the servo lead, then just red to red and black to black. Airtronics had the negative lead in the center of the plug, requiring a plug which absolutely could not be plugged in bassakwards, since doing so would let out the magic smoke that servos need to operate
Some folks just reverse the center black and the red wires, this will work, but the thickness of the old style Airtronics plug is greater than modern servo plugs, so they may need to be sanded down a bit and mark the signal wire (outer black wire on the original servo lead) with some nail polish, then plug it in with the signal wire closest to the little slot in the case for the standard Futaba "J" connector. All this applies to all modern receiver, even post 1997 Airtronics
Best of luck and enjoy flying in the FASST lane[8D].
Pete
Old 06-17-2011, 06:10 PM
jstrach
jstrach's Avatar
ORIGINAL: pilotpete2
Awesome Pete, thanks for the info! Will give her a shot....
Old 06-18-2011, 08:26 AM
carrellh
carrellh's Avatar
this pic describes the connectors and how to remove the pins to move the old style atx wires to match modern receivers
Old 06-18-2011, 08:36 AM
jstrach
jstrach's Avatar
That's a great diagram, thank you very much!
Old 06-18-2011, 08:50 AM
EloyM
My Feedback: (194)
YOU CAN NOT exchange the older Airtronics black ribbed connectors with Futaba or any other plastic plugs.
The internal pins are different and are locked in differently. To go to Futaba or any other plugs, even the newer
Airtronics "Z", you will need to replace the pins themselves. To do so, you will need a set of pins/plugs and
a crimping tool, such as available from www.cermark.net. Cermark also has adapters from Airtronics to
Futaba or the universal plugs.
The previous info about reversing the positive and negative, red and black, wires is correct.
Old 06-18-2011, 08:56 AM
jstrach
jstrach's Avatar
ORIGINAL: EloyM
The link is actually www.cermark.com
Thank you Eloy.
Update:The adaptor appears to be $3.50 (a little pricey).
Old 06-18-2011, 09:00 AM
carrellh
carrellh's Avatar
I saved it from one of RCKen's posts. I have quite a few diagrams saved from the years on RCU.
Adapters are expensive. I'd move the pins around in the existing connectors and sand them until they fit the receiver.
Old 06-18-2011, 09:06 AM
jstrach
jstrach's Avatar
ORIGINAL: carrellh
I just did an estimate in ordering 4 adaptors, with shipping - it's $23 bucks. I'm almost at 2 new servos at that price.... so I'm leaning towards what you're saying. :-)
Old 06-18-2011, 09:11 AM
Rodney
ORIGINAL: EloyM
Airtronics ''Z'', you will need to replace the pins themselves. To do so, you will need a set of pins/plugs and
Sorry but yes you can modify the old Airtronics connector but it takes a bit of work. First exchange the center wire and the red wire. Now, sand or grind off the ribs on the side of the connector body to slim it down to what will fit in the modern receivers, you may have to chamfer a corner or two as well. I have done this successfully on several old Airtronics servos to use on some old beater/trainer planes and am still using them. A better way is to just cut off the old connectors and splice in some modern ones with the proper polarity carefully adhered to (red wire on the center pin).
Old 06-18-2011, 09:44 AM
jstrach
jstrach's Avatar
ORIGINAL: Rodney
The pin swap took less than 30 seconds... and the dremmel tool took off the tabs in less than 15 seconds... so it's a pretty quick operation. SUCCESS!!
UPDATE:Iended up using an extension on each servo so that the plugs would fit neatly into the Rx. I had two 12" Futaba J extensions already, went to the local shop and bought two more at $5 / each. So for $10 bucks Ihave my plane now converted over to my 2.4 FASSTsystem. Now to finish recovering the plane.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
