Ignition Switch/Charge Port & 2.4GHz RX
Old 06-29-2011, 08:15 AM
dasintex
My Feedback: (10)
dasintex's Avatar
Default Ignition Switch/Charge Port & 2.4GHz RX
I would like to place both the Ignition and Receiver Battery Switch/Charge Port in the same Fuselage Switch Compartment that will also hold the Air Fill Valve, Air pressure gauge, etc; I am using 2.4GHz Futaba Fasst, and the RX placement will be in close proximity to these switches; I will also be using a Opti-Kill Transmitter operated Ignition Kill set up; any problems with interference with the RX, I know on 72MHz you had to place the Ignition Switch as far a way from the RX as possible; is this still the case with 2.4GHz?
Thanks.
Old 06-29-2011, 09:50 AM
karolh
Default RE: Ignition Switch/Charge Port & 2.4GHz RX
Because it is more tolerant than 72, going to 2.4 does not mean that the safe practices we observed to make flying on 72 safe should be discarded, as in most cases they are still required. My advice is to let common sense and good judgement prevail.
Karol
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
