reciever lites blink when turned on
Old 07-23-2011, 09:31 AM
Pete S-RCU
Default reciever lites blink when turned on
This happens to me periodically, when I turn on the xmitter and then turn on the receiver, the lites blink.
Not fast like it needs binding, it still works, I can move all the controls.
This is a Spectrum 7 ch receiver.
This happens with other receivers too.
I don't want to fly it this way, if I turn it off and power up again it will probably be OK.
What's going on?
Old 07-23-2011, 10:14 AM
BuschBarber
Default RE: reciever lites blink when turned on
ORIGINAL: Pete S-RCU
What's going on?
Some of the newer Spektrum Rx's show a blinking light when power has been momentarily lost to the Rx. Perhaps your switch Harness or Rx battery has a loose wire.
Old 07-24-2011, 04:27 AM
harley6133
i had this problem. it turned out to be the rx battery. the smaller sub AA battery pack doesn't have enough discharge current to turn on
the 2.4 receiver correctly. try a standard AA rx pack (i use the ones from expert with no problems)
Old 07-24-2011, 05:58 AM
Jezmo
Jezmo's Avatar
I agree with the posts by BB and harley. It's most likely not getting enough current when first turned on. Whether that is caused by not enough battery capacity or a poor connection is something to be worked out. I've got 12 receivers, all different flavors, and the only time this has happened I was testing the radio setup in the shop using a small AAA 4 cell pack I just had laying around. I went and retrieved a larger capacity pack, plugged it in, and the "problem" went away. A poor connection, whether the switch or a connector, could very well cause the same issue.
Old 07-24-2011, 06:30 PM
Ed
Put it on 6 volts !
ed
Old 07-25-2011, 12:09 PM
BarracudaHockey
BarracudaHockey's Avatar
If you turn off the reciever and turn it back on without turning off and on the transmitter, you get blinking lights indicating a power failure.
If its an electric plane and you fumble the deans while connecting them it can do the same thing.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
