2.4GHz - lost radio
2.4GHz - lost radio
I've just taken delivery of an RTF SkySurfer from Banana Hobby and being a noob to RC planes I'd like to get a sanity check to make sure I'm not doing anything wrong.
The kit comes with a 2.4GHz FlySky 4 channeltx and6 channel rx (the tx being a FS-T4C model, not sure about rx model). I bought this to learn to fly with so my first couple of flights didn't end well and in both cases I experienced a complete loss of control within 10 seconds of launch. Having rebuilt the thing with glue and tape I tried a 3rd launch which resulted in yet another loss of control. Before the 4th launch Ithought I'd mount the rx antena outside of the plane and try a range test.
Shockingly I managed to get no more than 25 feet from the plane before experiencing a loss of signal again. Is this right? I thought 2.4GHz shouldn't suffer from interference. Is it down to a) faulty operator (me), b) faulty transmitter or c) fault receiver? Is there anything Ineed to do before Ican fly?
Can anyone help?
As I imported this to the UK, I need to find out if it's faulty equipment before sending it back.
I should probably also add that when the plane goes down it makes a beebing noise, it's constant and the beeps are a few seconds apart. Does this indicate loss of signal from the tx?
Many thanks in advance
RE: 2.4GHz - lost radio
ORIGINAL: traxxasslash12
receiver and transmitter are no match
A thought occurred to me last night, could the symptoms I describe relate to a low/flat battey? I'm not convinced my charger is working and have ordered another so I'm not sure of the current state of the lipos.
Many thanks
You'd think so wouldn't you, but by the time I've paid the import duty and UKdelivery it's ended up costing a bit and am wondering whether I would have been better to get a model in the UK. I won't be thinking this once I get the thing up in the air though...
Moderator
