Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > RC Radios, Transmitters, Receivers, Servos, gyros
Reload this Page >
Questions about making a rudder and steerable Wheel!!!
Old 08-14-2011, 12:38 PM
roychadwickavrovulcan
Default Questions about making a rudder and steerable Wheel!!!
Hi,
This is my first post,
I was woundering if somebody could please tell me how i make a rudder and steerable wheels and what would be the easiest way
and what parts would i need
By the way the plane i am wanting to make is a Avro vulcan B.2 XM655
Thanks for reading
Jarod
Old 08-14-2011, 02:15 PM
BuschBarber
Default RE: Questions about making a rudder and steerable Wheel!!!
ORIGINAL: roychadwickavrovulcan
Hi,
Thanks for reading
Jarod
Depending upon how many channels you have, connect the Rudder to the Rudder channel and the Nose Wheel to a Free channel. Use a programmable mixer to mix them. I am doing the same thing with a Tail Wheel. If you don't have enough channels, use a Matchbox.
Old 08-14-2011, 03:51 PM
A.T.
ORIGINAL: roychadwickavrovulcan Hi, This is my first post,
and what parts would i need By the way the plane i am wanting to make is a Avro vulcan B.2 XM655 Thanks for reading Jarod
<dt>Please refer several informatative " Pull Pull"setupsunder sub section
"Aircraft Design. Airfoils, Pull-Pull Systems, Flight Trim & Static Thrust Calculator."
and steerable nose gear installations under sub section
"Retract Undercarriage, Flaps and payload release" at
Alan's Hobby, Model & RC FAQ Web Links
and if using a Hitec Aurora 9:
Aurora 9 - Retract Wheels - Steerable - Lock Steerable Nose & Tail Wheels whilst retracted.
Whilst Vulcan has nosegear the following may also be of interest::
Tailwheel Construction and Fitting </dt><dt>Tailwheel Construction (DIY Scale Leaf Spring) - RCFU
Alan T.
</dt>
Old 08-14-2011, 06:00 PM
BuschBarber
Hi,
Thanks for reading
Jarod
Jarod - I assume you are talking about a Nosewheel bucause there are not any Jets that I know of that use a Tail Wheel. If you are not using Channel Mixing, the JR Matchbox (and the Futaba equivalent) allow you to connect up to 4 servos to one channel and adjust Neutral, End Points, and Servo Direction, for each servo.
Old 08-16-2011, 02:51 PM
Thanks Ev erybody i have wrote all that down and thanks again
Jarod
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
