Futaba 7C transmitter Airplane or Heli?
NC
Does mod# 7CA24GRX on a Futaba 7C mean airplane or helicopter? Can the rachet gimbels be changed from right to left or left to right without returning to Fubaba?
My Feedback: (19)
WA
RE: Futaba 7C transmitter Airplane or Heli?
Futaba 7C Airplane version 2.4Ghz, probably was sold with a receiver as a pair. According to the manual I downloaded from www.futaba-rc.com, page 15 says that the service center must change the ratchet.
Most folks do the swap themselves. Very easy to do. A small pull type spring hook is a help, but not necessary, though you can make one out of a paper clip, using fine pointed needle nose pliers to make a hook on one end. The mechanical part of changing the stick mode involves moving the ratchet leaf spring (small, #1 Phillips screw) to the side that will now be the throttle stick, and moving the centering arm and tension spring for the elevator stick centering. The bit in the manual is just "CYA", though to be fair, there are some folks that should not be allowed to have a screwdriver, or any pointy object in their hands[&o].
Best of luck,
Pete
Best of luck,
Pete
My Feedback: (19)
ORIGINAL: cphdrider
