Help with Jr11x zero
Ive just got one of these radio's and im made up with it,one thing i cant get to work is the expo when you mix two channels together ,it will only work on the master channel but not on the slave,the trim and D/R work fine,any help would be appreciated,BTW in using mix 1
Cheers
Ian
Cheers
Ian
RE: Help with Jr11x zero
ORIGINAL: ian51291
Cheers
Ian
Cheers
Ian
Rich’s suggestion of using the mating function on the Wing Type menu is the quickest and easiest way to couple two channels so they have common trim, rates and expocurves. The 11XZero programming is not entirely the same as used with the transmitter sold in the US. On mine it is possible to use the program mix to have the same dual rates for two channels through sub menus. When the throttle, rudder, aileron, elevator or flap is selected as the master channel, a submenu will pop up asking which include functions are to be transferred to the slave.Expo is one of the possible include functions for the aileron, rudder and ailerons. If your transmitter programming doesn’t do this, you will have to use the Wing Type mate function.
Allan
Thanks for the reply guys,i was playing around with the menu and noticed the channel mate,all sorted now
Cheers
Ian.
Cheers
Ian.
