Dymond Radio
FL
Dymond Radio
Hi everyone, Does anyone know anything about these Radio's, they say that they can convert any 72mhz radio in a 2.4 system. I have around 6 of the 72 mhz radios and I hate to toss them and buy new Radios for my planes..the Company is out of Homestead Fl. and its called DYMOND USA.
Thanks for any input about this.
AZ
RE: Dymond Radio
I don't know anything about Dymond but converting a radio to 2.4 is a simple thing to do.
Almost any good technician can do it.
You will be stuck with getting receivers from them for the rest of your life unless you get them to use modules from JR or Spectrum or one of the other major manufactures.
RE: Dymond Radio
One of our club members has the Dymond and it works very well the only potential problem is the bind time is about 30 seconds so any inflight problems could be fatal. I use the standard 8 channel Frsky conversion from Hobby King it is less expensive and has about a 1 second bind time. I have 2 [both on Futaba 8UAP transmitters] and have used them for a year and a half without any problems.
Gary
Gary
RE: Dymond Radio
ORIGINAL: Roo Man
Gary
Gary
Binding only has to do with saving the transmitters unique ID to the receiver, so that the receiver only responds to the transmitter it is Bound to. A Link is established whenever the Tx and Rx are turned on. The Link can be blocked by Interference, etc. When the Link is restored, all is well. If the receiver voltage drops to a critical level, the receiver will ReBoot and then Link again to the Tx.
The faster the ReBoot, the shorter the time that control is lost. This has nothing to do with Binding. Early Spektrum receivers, as an example, suffered from slow ReBoot (5sec) after a Brownout. Subsequent firmware updates shortened that ReBoot time to a second or so.
Frequently, when discussing various 2.4 radio incidents, the term Bind is used instead of Link.
