I'm a Newby Again
FL
I'm a Newby Again
I've been out of the hobby for 20 years. I bought a fixer-upper on Craigslist and am ready to install my receiver.When I built my last model, mixing was either mechanical, or if you were really slick, you used a Christy Mixer.I still got one in my toolbox. Now it is all done in the radio and I am not sure the best way it all up. I have a 6 channel radio and will be using 5 channels (throttle, elevator, rudder, ailerons, and flaps). My ailerons are using 2 servos and the manual says to plug one servo in the aileron channel and one in the flaps channel and them mix them in the radio...but then, what do I do with the flaps? I'd really like the actual flaps to be on the variable flaps channel.The other channel is either on or off.Can I use that one for the ailerons?I hate to sound stupid, but what happens if I use that channel and then flip the switch?Does my model fall out of the sky?
RE: I'm a Newby Again
ORIGINAL: jlander
I've been out of the hobby for 20 years. I bought a fixer-upper on Craigslist and am ready to install my receiver. When I built my last model, mixing was either mechanical, or if you were really slick, you used a Christy Mixer. I still got one in my toolbox. Now it is all done in the radio and I am not sure the best way it all up. I have a 6 channel radio and will be using 5 channels (throttle, elevator, rudder, ailerons, and flaps). My ailerons are using 2 servos and the manual says to plug one servo in the aileron channel and one in the flaps channel and them mix them in the radio...but then, what do I do with the flaps? I'd really like the actual flaps to be on the variable flaps channel. The other channel is either on or off. Can I use that one for the ailerons? I hate to sound stupid, but what happens if I use that channel and then flip the switch? Does my model fall out of the sky?
The simplest method would be to connect a Y Harness to the Aileron channel on the receiver and then connect each Aileron servo to the Y Harness. This would allow you to connect Elevator, Rudder, Flaps, and Throttle, to their respective channels.
Despite the fact that the Gear channel is assigned a two position switch, it is usually a proportional channel. If you have sufficient programming in the transmitter, you could mix the Aileron and Gear channels, for Dual Ailerons, and Inhibit the Gear switch.
Some transmitters have a Wing Type or Tail Type program that allows you to choose Dual Ailerons. Others require the use of a Programmable Mixer program. You could most likely use the Gear channel as the second Aileron half.
Only as a last resort.
It all depends on the radio. I avoid using a "Y" harness on primary control surfaces if at all possible. Using a "Y" on the ailerons losses the ability to program in some differential.
If there's a Will, there's a way, or at least I hope I"m in it
Pete
Pete
ORIGINAL: MinnFlyer
And I'm just the opposite. I avoid using two channels unless I absolutely have to. Differential can easily be obtained mechanically by rotating the servo arms
I have used Y Harnesses for years, before computer radios. I have experienced many problems traced to a Y Harness.
FL
Thanks. Sorry I've not responded yet with my radio information. I'm a Florida State Trooper and because of those big accidents in Florida on I-75, for the last day and a half I've putin 24 hours and todayI'm scheduled for 14.
I have a Futaba 6XA that is brand new in the box that was given to me. It is capable of mixing with the gear channel. I didn't know you could deactivate the gear controls, so that sounds like what I'm going to do. Since I have the channels available, and I've never had a programmable radio before, I'd like to give that option a try. The Y-adapter is an option I'll keep open though.
My model is not a trainer although it is trainer like.It is very large and flaps will be nice. I've posted a photo and there are more here: http://www.rcuniverse.com/forum/m_10926684/tm.htmif you know what this model is. Because I purchased it off Craigslist, I don't know much about it. It looks like it might be a wing from a Spook mated to something else.
ORIGINAL: jlander
Thanks. Sorry I've not responded yet with my radio information. I'm a Florida State Trooper and because of those big accidents in Florida on I-75, for the last day and a half I've put in 24 hours and today I'm scheduled for 14.
My model is not a trainer although it is trainer like. It is very large and flaps will be nice. I've posted a photo and there are more here: http://www.rcuniverse.com/forum/m_10926684/tm.htm if you know what this model is. Because I purchased it off Craigslist, I don't know much about it. It looks like it might be a wing from a Spook mated to something else.
FL
I hooked upthe servos and installed the receiver today. I could not get the aileron programming to work right when I kept the flaps on the flaps channel. So...I went out and bought another y-harness and I'll do it the old fashioned way. The motor won't run because the carb is all gunked up.The new carb I got has a choke so I think I'll use the extra channel to operate it.
I noticed that when operating the flaps, one seems to lag a little behind the other. It over travels a littleand kinda wags back and forth until it finds the correct position. This only happened when operating the controls quickly. The flaps are already hooked up with a y-harness. I don't know what kind of servo is used because they were already installed in the wing and I didn't want to take them out and have to worry about fishing the servo wire back through the wing. Any ideas of what is causing this?
FL
I figured out the servo problem. I had a bad y-adapter. I got my receiver installed and connected all the servos and everything is working the way it should. I pick up the engine tomorrow and other than a little more trim work on the covering and checking the balance it is done.
My Feedback: (13)
ORIGINAL: jlander
ORIGINAL: jlander
http://manuals.hobbico.com/fut/6ex-2_4ghz-manual.pdf
The T6XA is a 72Mhz radio.
I had two T6XA radios, years ago. One was on Ch44 and one was on Ch46. They were my first computer radios. They only had 3 Model Memories, so I bought a second one so I could have 3 more Model Memories. Because you could not Name each Model Memory, I had Labels on the back of each transmitter to identify which aircraft was assigned with which Model Memory.
After all these years, and many more advanced radios, I assisted a friend in setting up his T6XA, last year. That is when I realized how limited the programming choices were.
Is this your radio?
http://manuals.hobbico.com/fut/6xas-hs-manual.pdf
You need to enable the Flapperon function by changing the value from INH to On.
Right Aileron servo connects to the Aileron channel and Left Aileron servo connects to the Flap channel.
See page 30 and 31 in the manual.
By default, you see 100%. Some aircraft, like high wing aircraft, benefit from having more Up Aileron than Down Aileron. This is called Differential. You can adjust that percentage in the Flapperon function
You need to adjust the Flap Trim function to control the amount of Deflection of the Flaps when you turn the Flap knob.
There is also a Futaba 6EXA.
http://manuals.hobbico.com/fut/6exa-manual-v1_1.pdf
This has a Wing Mix (w.mix) that can be set to Flapperon (Ch1 and Ch6). See Pg 17 about the removable Flap Control Lever.
