Transmitter turns left always
I'm trying to use a Radiolink T6EHP-E on Clear View. But for some reason when I use the throttle it always does a hard left turn at the same time and crashes. I checked with the windows game calibrator and the line goes diagonally from top left to bottom right. Any suggestions?
RE: Transmitter turns left always
I would check to make sure the channels are assigned to the correct controls. Make sure the rudder and ailerons only respond to the correct channel inputs.
Woodie
Woodie
