Turnigy TGY9x, Timer
TX
How does one turn on the timer on this radio.
I have it programmed for the minutes needed, but the manual does not address activating it.
BTW, I have used this radio for some time without incident. If it had a decent operating manual I would like it.
My Feedback: (325)
RE: Turnigy TGY9x, Timer
Activate the timer in the same menu , and then turn it on and off with the most forward , right momentary switch. Pull switch toward you with right index finger for regular humans.
TX
Well I'll be da*****, it works.
How did you find this information. I have searched the so-called manual from front to back. I've used the radio for a year without using the timer.
Thanks.
Thanks.
My Feedback: (325)
Here's the best manual I've found and I found it on pg 34 (timer, airplane section)
I'm going to try to attach the PDF here. It's the IMAX manual and I can't seem to attach it.
You may try to download one here, but my pc seems to be having trouble doing anything right now. http://www.filadelfosrc.com/Manuals/
TX
Thanks guver. Right now that site is having big time problems and the manual will not download.
I'll try it later. A good manual would be nice to have.
I appreciate your help.
