7202 Heli for Aircrafty use
Old 06-26-2012, 04:41 PM
prgonzalez
prgonzalez's Avatar
Default 7202 Heli for Aircrafty use
Can I use the 7202 Heli version for Aircraft use?
Are these versions software specific for heli or air?
Old 06-27-2012, 04:40 AM
BarracudaHockey
BarracudaHockey's Avatar
Default RE: 7202 Heli for Aircrafty use
Sure, just select airplane mode in the programming.
The only difference is maybe the 3 position switch position and the throttle won't have a ratchet.
Old 06-27-2012, 05:57 AM
prgonzalez
prgonzalez's Avatar
Hi Barracuda,
So, what I understand you saying is the aircraft programming is already in the radio. I can live without the ratchet.
What about the three position switch, Does it perform a different function when programming is changed to airplane compared to the native aircraft radio?
Could you explain more.
Old 06-27-2012, 06:37 AM
BarracudaHockey
Having not messed with that particular radio my answer may not be 100 percent accurate but in general with the JR stuff that I am very familair with it goes like this.
The top of the transmitter has a 3 position and two position switch, with airplanes this is classically the flap (3pos) and retract switch. On radios with the A designation the 2 position is on the left and the 3 pos on the right and of course the throttle has the clicker. On the H designated radios the 3 pos is on the left side and the two position is on the right, and no clicker on the throttle. We use the 3 position for flight modes and the two position for throttle hold.
As for the programming in relation to the switches nothing really changes other than if you're using an A version your flap switch is (probably) on the left instead of the right.
I pulled the manual and it shows programming for both Airplane and Heli mode.
Old 07-03-2012, 12:52 PM
prgonzalez
prgonzalez's Avatar
Thank you for your assistance. I was able to find one aircraft model out of ebay.
