Elevons?
Old 07-18-2012, 12:54 PM
Microz
Microz's Avatar
Default Elevons?
Hello. I have an AR6410 spektrum ultra micro board i am using for a scratchbuild. This is a delta so there has to be elevons. The aileron mix works perfectly, but the elevator mix does the exact same thing as the aileron mix (ie it functions like ailerons and not an elevator). What can i do to fix this? Im using a spektrum dx7s in case it helps.
Old 07-18-2012, 02:09 PM
Microz
Microz's Avatar
Default RE: Elevons?
Nevermind i got it figured out. I had to change the wing type in the settings. Took me 4 hours just to figure that out.... [:@]
