Hitec Aurora9 or JR X9503 Which is better and why?
My Feedback: (15)
FL
Trying to decide which radio to purchase for my 100cc Extra 330L. I am driving myself crazy at this point!
I like the JR set-up with the satellite receivers, somehow makes me feel like no matter what attitude the airplane is in, it will always get great reception.
Hitec's Aurora 9 has some great features and I can get it for well over $200 less than the JR.
I have 3 other Hitec radios and I like them all for various reasons. I am inclined to go A9, simply because I am NOT a pilot that can use, or needs, a top of the line system, but the JR has some features I like.
If they were both brand new in the box in front of you, which one would you chose and why?
RE: Hitec Aurora9 or JR X9503 Which is better and why?
I am not going to help much, I would choose the Hitec, because I am on a tight budget. I would say, the only thing that would concern me is if either of the radios have a better or worse track record with kill switches on gas engines. I have heard a couple of "problems" with the hitec, but I don't have enough knowledge of the larger planes to make a judgement call. If budget is of little concern, I would go with Futaba.
ORIGINAL: Taz_Hobbies
The Hitec A9 is a modular Tx and can communicate with any Rx that it's modules support. Hitec 72Mhz modules support any Hitec 72Mhz or 2.4Ghz Rx's. 3rd party modules can be purchased from Spektrum, Futaba, XPS, etc.
I personally like the Spektrum DX18 over the JR9503.
I have the Hitec gear and I have flown at heights of above 1000 meter that is quiet a range check and as I'm in Australia I think we run lower transmitter power to the states. May be some one can give us the distance the JR gear will go My 2 cents worth Yours Paul T
ORIGINAL: Quigleywins
I bought my first Aurora 9 when they first came out and liked it so much I bought a second. One for IC engines and one for electrics. I can use the other transmitter as a buddy box or as backup if something happens to the primary one I am using. For buddy box or backup just attach the patch cord and copy one to the other and have perfect identical setup on both. Never had an easier transmitter to program prompts you through the setup and its all touch screen. I love mine.
As to other brands I have limited experience all I can say is that if any one brand were so much better than the others we would all be flying that brand. Pick the radio that best suites your needs. One you find comfortable to hold on to. One you have confidence in otherwise you may never be happy. One last thing to consider if you are less than comfortable with programing and working through the manuals might be to buy one that is common at your flying site that way there should be lots of help available to shorten the learning curve.
Dennis
Dennis
ORIGINAL: Propworn
As to other brands I have limited experience all I can say is that if any one brand were so much better than the others we would all be flying that brand. Dennis
Disclaimer: I'm biased!
Aurora 9
1. Easiest radio on the planet to program with it's large back lit touch screen and open architecture so that anything can be assigned anywhere! http://www.youtube.com/watch?v=T27DZNCMP1A
2. Built in Rx battery telemetry/warnings with additional telemetry options available. http://www.hitecrcd.com/products/air...try/index.html
3. Single or Dual BODA's (Boosted omni directional antenna's) for easy installation! http://www.hitecrcd.com/products/air...ghz/index.html
4.Huge database of info/FAQ's available: http://www.rcuniverse.com/forum/fb.asp?m=10907906
In reality, the Aurora is closer to the new JR XG11 in features but at less than half the cost!
Compare manuals here:
http://www.hitecrcd.com/files/Manual_Aurora9.pdf (Latest update: http://www.hitecrcd.com/support/firm...rora9v108.html )
http://www.horizonhobby.com/pdf/JRP2930-manual.pdf
http://www.horizonhobby.com/pdf/JRP00615-Manual.pdf
Mike.
Aurora 9
Mike.
http://www.jrradios.com/Content/PDF/Challenge_AD_4.pdf
Andy
My Feedback: (15)
FL
Thanks for the input fellas. I appreciate it. I am going to stick with the Hitec. I ordered the A9 yesterday afternoon.
