JR Receivers
JR Receivers
Ihave 2 FM RX, need to know what radios they work with. R955S and R770S Both on channel 44. Wonder if they will both work with the same radio.
RE: JR Receivers
If radios are the same around the world the answer is yes, I have an old JR Max66 transmitter and I use it with 3 differant JR recievers, 2 Bluebird recievers and one Hitec. All work well with no issues, Australian radios work on 36Mhz FM, your US gear if it's on 72Mhz FM should be OK.
RE: JR Receivers
ORIGINAL: iflylilplanes If radios are the same around the world the answer is yes, I have an old JR Max66 transmitter and I use it with 3 differant JR recievers, 2 Bluebird recievers and one Hitec. All work well with no issues, Australian radios work on 36Mhz FM, your US gear if it's on 72Mhz FM should be OK.
PCM receivers are proprietary to the individual brands but over the years each brand produced several new
PCMtypes which did not work with earlier own brand Tx - user needs to match PCM, SPCM, QPCMetc to the various transmitters.
Standard PPMreceivers are not universal either.
27Mhz <41 Mhz are generally univsersal with a few exceptions when used with transmitters with a synthesised module installed.
The main problem is with 72MHz &75Mhz in that "frequency shift" either Positive such as JR&Sanwa (aka Airtronics)
and Negative shift such as Futaba and Hitec, refer:
Negative and/or positive shift in Transmitters and Receivers - 101 re Differences
All recent Hitec, JR x 1 and a few lesser known brand PPM receivers do have "auto shift"
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
