RC OMG servos
NJ
RC OMG servos
Hello everyone its Joey B from Version 95 and Hono Circuit. I just wanted to give everyone a heads up on a new servo company RC OMG.I am currently waiting on my test units, however my good friends from the UK Tom Wendtland and Peter Gray have got theirs and love them.
We all got RC OMG‘s new low profile digital brushless servo part number HDT045070B. Based on Pete and Toms first hand results, and the specs listed below these seem like amazing servos for many dif uses.
Item No. HDT045070B
Type Digital
Operating Voltage Range 6.0-7.4Volts DC
Bushing or Bearing Bearing
Bearing Type Dual Ball Bearings
Speed (s/60°@4.8V/6.0V) 0.06/ 0.05
Torque oz./in. (4.8V/6.0V) 76/97
Torque kg./cm. (4.8V/6.0V) 5.5/7
Size in Inches 1.58 x 0.79 x0.99
Size in Millimeters 40.2x 20.1x25.2
Weight oz. 1.59
Weight g. 45
Motor Type Brushless motor
Control System +Pulse Width Control 1500usec Neutral
Required Pulse 3-5 Volt Peak to Peak Square Wave
Operating Temperature Range(F) 14° - 122°
Operating Temperature Range(℃) -10° - 50°
Idle Current (@6.0V/7.4V) 4mA/5mA
No Load Running Current (6.0V/7.4V) 300mA/400mA
Stall Current (6.0V/7.4V) 3200m/3900mA
Dead Band Width 2µs
Potentiometer Type Rotating(Max.220°)
Connector Wire Length 11.8 in. / 300 mm.
Connector Wire Gauge 25 AWG
Connector Type JR
Gear Type Titanium gears
Shaft 6mm 25T
I have attached some photo’s of the servos on Tom's and Peter's Yokomo Drift chassis. They look great and perform betters. Stay tuned for my full review, pics and video
Item No. HDT045070B
Type Digital
Weight oz. 1.59
Weight g. 45
Dead Band Width 2µs
Connector Type JR
Shaft 6mm 25T
My Feedback: (79)
RE: RC OMG servos
To tell you the truth.. The cheap MG 995 are good as well.. I use them for my tmaxes and some of my smaller glow models'' The only thing I found wrong with that servo was that the motor was turning In the case and breaking a wire.. I have seen that in early FMA servos as well. And they have the holes for the screws So just use them.. Or goop the motor to the case. The goop in the purple tube..
RE: RC OMG servos
OMG means Only Manufacture Golden .
It means RC OMG Only Manufacture Golden products!
Yes, Tower pro is cheap, but its quality is not so good, but RC OMG is new brand which focus on the quality!
RE: RC OMG servos
RE: RC OMG servos
Thanks for Tom's video for RC OMG low profile brushless servos!
It looks awsome!
Wish you could enjoy it!
[youtube]http://www.youtube.com/watch?v=wdkuYLyp05Y[/youtube]
It looks awsome!
RE: RC OMG servos
Thanks for Daniel Christoph's Test video of RC OMG's LDT062070B
It looks awsome! Wish you could enjoy it!
Best regards
[youtube]http://www.youtube.com/watch?v=cX9fpnl2gPE&feature=player_detailpage[/youtube]
Best regards
RE: RC OMG servos
You can contact RC OMG via the email : [email protected]!
If you have any problem, please also contact us via email.
Do wish you could enjoy it!
RE: RC OMG servos
Here is the comments of Brett Crawford:
"Both servos are installed in our modified Clodbuster race trucks that race in the RCMTC race series.
- The 150L (the std. one) servo worked well and had plenty of power to turn the wheels on the high traction carpet. It seemed like it was a bit slower than the servo it replaced (the one we currently offer), but it did center well which is very important with these trucks. I'm including 2 pictures, one close up of the servo installed and another of the truck it was installed in.
- The 150B brushless servo worked great in the truck it was installed in. It replaced a Spektrum digital hi-speed servo and was noticeably faster than that servo. It is currently being run with a servo saver, but will likely get changed to a straight aluminum arm due to it having titanium gears. I'm including 2 pictures, one close up of the servo installed and another of the truck it was installed in. Also including a video the racers sent me. I wasn't able to open it, but it should show you the type of racing and vehicle this servo was installed in.
Pictures and video are yours to post/use however you need to. Both servos will continue to run in these trucks and I'll keep you updated as to how they continue to work in these trucks. Thanks!"
Brett Crawford - Owner
Crawford Performance Engineering
RE: RC OMG servos
Now it is Christmas Eve in China!The new 2013 is coming, the 2012 is not the end of the world, so do the 2013.In the new year, do wish all of my friend have a merry Christmas and a happy new year!Do wish we could have the good beginning the in the year 2013!Best regards,Tony Ho From RC OMG
RE: RC OMG servos
Thanks for Tom's Video .
That is the test of RC OMG's Low profile Brushless Servo HDT045070B.
Wish you enjoy it !
http://www.youtube.com/watch?feature=player_embedded&v=T2Kha1IsXhU[
youtube]http://www.youtube.com/watch?feature=player_embedded&v=T2Kha1IsXhU[/youtube]
Wish you enjoy it !
RE: RC OMG servos
Here is the test video by Daniel Christoph from Germany.
http://vimeo.com/56701366
He used RC OMG's LDT062070B Brushless servo!
Here is the data of this servo:
http://www.rcomg.net/index.php?act=pShow&id=33
Technical data
Item No. | LDT062070B |
Type | Digital |
Operating Voltage Range | 4.8 -6.0Volts DC |
Bushing or Bearing | Bearing |
Bearing Type | Dual Ball Bearings |
Speed (s/60°@4.8V/6.0V) | 0.06/ 0.05 |
Torque oz./in. (4.8V/6.0V) | 69/97 |
Torque kg./cm. (4.8V/6.0V) | 5/7 |
Size in Inches | 1.58 x 0.79 x1.53 |
Size in Millimeters | 40.2x20.1x38.9 |
Weight oz. | 2.19 |
Weight g. | 62 |
Motor Type | Brushless motor |
Control System | +Pulse Width Control 1500usec Neutral |
Required Pulse | 3-5 Volt Peak to Peak Square Wave |
Operating Temperature Range(F) | 14° - 122° |
Operating Temperature Range(℃) | -10° - 50° |
Idle Current | 5mA |
No Load Running Current (6.0V/7.4V) | 110mA |
Stall Current (6.0V/7.4V) | 2800m/3000mA |
Dead Band Width | 2µs |
Potentiometer Type | Rotating(Max.220°) |
Connector Wire Length | 11.8 in. / 300 mm. |
Connector Wire Gauge | 25 AWG |
Connector Type | JR |
Gear Type | Titanium gears |
Shaft | 6mm 25T |
NJ
RE: RC OMG servos
ok guys i have been super slow to respond, i been sick, running an rc track and 2 rc forums, all while being in an RC drift team is a lot of work
Well i love my servo, its smaller, faster and stronger than my futuba , so so0000 fast. im in love cant wait to get more packs in here.
the only problem i see so far is that the servo horns and screw where to hidden in the package i almost tossed them. Well on with some pics
RE: RC OMG servos
Now it is Chinese New Year !
Just wish all of you have a healthy and wealthy new year in the Chinese Snake Year!
Wish all of you and your family will be happy everyday in the Chinese Snake Year!
新年快乐!恭喜发财!万事如意!
