Hitec Eclipse 7 radio equipped with a Frsky 2.4ghz module
My Feedback: (27)
ID
RE: Hitec Eclipse 7 radio equipped with a Frsky 2.4ghz module
I have the Hitec 2.4 conversion, I use Hitec RX's and it works well for me. I have two of these transmitters, one I keep on 72 to keep some of that stuff in use. Not much channel overlap anymore.
Don't think I would use an off-brand set up when the Hitec works so well and not that expensive.
ORIGINAL: DUHAWK49
was thinking about upgrading the radio to 2.4ghz.. my question is if I put a Frsky 2.4ghz module on the radio, what receivers can I then use with it? thanks for any help
FrSky is like all other 2.4 systems and will only operate with FrSky receivers. I switched from 72 to 2.4 with a FrSky module in my Fut Tx and it's been rock solid for the 2 years I've been using it. Because FrSky is a lot cheaper that the other big radio manufacturers does in no way means that they are inferior in performance, as they have been proven to be just as good and in some cases better.
Karol
ORIGINAL: DUHAWK49 was thinking about upgrading the radio to 2.4ghz.. my question is if I put a Frsky 2.4ghz module on the radio, what receivers can I then use with it? thanks for any help
extract:
". Hitec Eclipse 7, Optic 6 and Prism DIY Remote 2.4Ghz Antenna Mount Convert PPM/QPCM units to 2.4GHz - with Telemetry.
. Hitec AFHSS 2.4GHz Aircraft Receivers & Modules
. Hitec USA Support Forum Sticky:
. Hitec AFHSS 2.4GHz Spectra Modules, Optima Transceivers & Telemetry - FAQ & Undocumented Features
(Use I-phone or Android as a screen and/or HTS-Navi wireless to Laptop)
. Eclipse 7 - For Horizon BNF models use the Spektrum "Futaba" DSM2 module.
Lower Mast Spacer may be shortened to reduce height. Wrap with a piece of tape for a snug fit and easy removal
. Eclipse 7 & 7 Pro - Tactic AnyLink Setup
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
ORIGINAL: DUHAWK49
does it just plug on in the back or do any mods have to be done?
No mods required, just plug and play .
Karol
I've been using the FrSky module in the Hitec for a couple of years now with no problems. You do need to use the Frsky receivers though as, like all other systems, they work only with their own receivers. I have found the Frsky systems to be extremely reliable.
ORIGINAL: DUHAWK49
I just ordered one with receiver.. hope to try it soon.. if it works well I will get more.. thanks for the help
