Servo trouble
Servo trouble
Hey,
I just got a 60 size sport aircraft. I installed JR standard servos and have a problem. For example, I move the elevator control stick around. When I let it recenter the servo makes a buzz like something is pushing against it. Ibelieve Ihooked them upright!!
Anysuggestions?Does this hurt them???
Thanks!!!!!!!!!!!!!!!!!!
CA
RE: Servo trouble
Aha.Brand new CA hinges? Did you glue them yourself or were they installed? The hinges are likely just stiff.Take the linkage off and work the surface back and forth to the limits.Dont force them but bend them all the way over till they snugly stop.Back and forth back and forth.Should loosen them up a little after a dozen or so cycles.
