Spektrum telemetri with dsm2 recivers
How to use spektrum telemetry TM 1000 along with a DSM2 receiver.
Various problems may occur depending on the receiver you are using, but one thing will solve all problems, an extension cord between TM 1000 and the reciver after it is binded in the normal way.
All the receivers that have a BIND/DATA port you leave the signal wire intact for flight log information to be displayed/recorded.
Almost all the receivers that have a BIND/BATT port you remove the signal wire to prevent triggering BIND mode on the TM1000.
Cheers
S
