EMS GoSlow with JR Matchbox?
The airplane I'm building has flaps, each run by their own servo. I have these servos controlled via a JR Matchbox in order to set servo direction and end points. Now, I'd like to slow the flaps down and be able to use the 3-position switch on the TX for Up, Takeoff, and Landing flaps, but I want them to move slowly at realistic speeds. So far I am unable to determine if these two electronic "doo-dads" are compatible. Anyone able to offer any insight as to if they are and if so how to hook it all up?
Thanks!
Kurts
Thanks!
Kurts
RE: EMS GoSlow with JR Matchbox?
ORIGINAL: KurtS
The airplane I'm building has flaps, each run by their own servo. I have these servos controlled via a JR Matchbox in order to set servo direction and end points. Now, I'd like to slow the flaps down and be able to use the 3-position switch on the TX for Up, Takeoff, and Landing flaps, but I want them to move slowly at realistic speeds. So far I am unable to determine if these two electronic ''doo-dads'' are compatible. Anyone able to offer any insight as to if they are and if so how to hook it all up?
Thanks!
Kurts
Thanks!
Kurts
You did not mention important details such as what Tx and Rx you are using as well as what servos you are using. The Tech Notes do not mention 2.4 radios but I would suspect that this product will work with the Matchbox. Have you tried to hook it up, yet?
I haven't purchased the GoSlow yet, I want to try and determine if it will work, first.
The radio is a Spektrum DX7 with their AR7000 receiver and the servos are Hitec HS645MGs.
Kurt
Kurt
