6.6 life receiver battery
I have a new life battery pack that I was going to use to power my AR6200 and servos. I thought I was buying a 6 volt pack but it says 6.6 volt on the pack. Is it safe to use this 6.6 volt pack ? I think I read Spektum says the AR6200 will go to 7.2 but I wasn't sure. Thanks for you help !!
ORIGINAL: drdave427
Keep in mind, the Nominal voltage for a battery pack is lower than the Fully Charged voltage. LiPos have a Nominal Voltage of 3.78v per cell, but charge to 4.2v per cell. If a device is rated for 7.4v (Nominal Voltage for a 2cell LiPo pack) then it will be fine at 8.4v (fully charged 2cell LiPo pack). There are HV servos that are compatible with 2cell LiPos and run fine at 8.4v.
LiFe batteries have a very flat discharge curve and sit at 3.3v/cell until they are fully discharged. LiPos will slowly lose voltage as they discharge so they are easy to monitor with an Expanded Scale Voltmeter (ESV). LiFe batteries will not show a measurable voltage drop so you need to keep track of how much time they have been in use in order to determine when to recharge them.
TX
I have been flying with LiFe receiver batteries for over 2 years with excellent performance. I used NiCads for many years...then switched to NiMH....then moved on the LiFe which are the best yet. They hold their charge over an extended period of time and they don't develop a "memory" as the NiCads do. They are safer than LiPo batteries and no voltage regulator is needed. From my own experience and everything I have read on batteries, these are the best batteries yet for modern radios including digital servos.
JC
I don't always fly R/C...but when I do, I fly FASST. Fly well my friends.
JC
AB, CANADA
ORIGINAL: drdave427
Product Specifications
Type:Full Range Aircraft Receiver# of Channels:6Modulation: DSM2/DSMXBand:2.4GHzLength:1.19 in (30.1mm)Width:1.03 in (21.6mm)Height:0.48 in (12.3mm)Weight:0.35 oz (10g)Voltage Range:3.5–9.6VAntenna Length:Main Rx: 30mm (2); Remote Rx: 30mm (2)
OK - thanks guys. Now one more issue. My old receiver pack has 3 wires like a servo wire but the life battery only has two. My plane has a charge jack/switch on it also. Is the third wire something to do with charging the old NIMH pack ?? I plugged the life battery into the jack than runs to the switch then on to the receiver and everything worked but I was worried about that third wire.
Thanks again for the help !!
ORIGINAL: drdave427
In the 2.4Ghz era, you can Bind Spektrum receivers by either inserting the Bind Plug in the Bind port on the receiver or inserting Bind Plug in the charge port on a 3 wire DSC compatible Switch Harness. This would not be possible with a Non 3 wire Switch Harness.
My Feedback: (41)
Well one of reasons the A123/LiFe batteries might have a two wire lead and a three wire lead, is balance charging.
The two wire lead would be for discharging or powering the model, the three wire lead will typically use the signal wire as a balance lead for charging. On the Spektrum/JR 2.4GHz radios, if you plug that three wire lead into the rx and then try to bind the rx, you'll let the magic smoke out of the rx....
Best to do a bit more research on what you have for a configuration of the wiring as there are a number of ways to do things with three wire HD switches and these batteries.
No I understand the balance charge lead of the battery. It is a Turnigy Nano tech and actually has 3 harnesses. The white balance charge lead , the black JR/Spektrum type plug I'm using(red and black wires) and a small red plug with red and black wires. I forget what that red type of plug is called but I only needed the JR/Spektrum plug and the balance/charge lead. Thanks again for the info !!
ORIGINAL: drdave427
ORIGINAL: drdave427 No I understand the balance charge lead of the battery. It is a Turnigy Nano tech and actually has 3 harnesses.
1. Three wire balance lead.
2. S-01 (Hitec / JR) servo plug with Red (+) and Black (-) leads to fit many different Tx.
2. JST (Tamiya) power plug with Red (+) and Black (-) leads to fit many other Tx such as GWS
or use to power small boats, mini cars etc.
Much more information available under sub sections
"Battery Care, Performance & DIY Battery Packs."
"Radio Systems, Accessories, Alterations and FAQ" at
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
Thanks Alan I have been reading about all this today (it's pouring down outside) you've given me MUCH MORE to read !!
Interesting read. Also poses another question. I am still using my old 72mhz Futaba 8ua radio. I just purchased the LiFe receiver batteries and the Hitec X4 charger to support them (and any future charging needs I may have) . That said, Should I use a reg ? The LHS says I am fine, but they may be thinking about the Spectrum Radio's/Receivers they carry.
ORIGINAL: ThunderBoat42
wear and tear which shorten the life of the servo. Sure, a fully charged 5 cell NiMH/NiCD battery is at same voltage but not for long.
Majority of known users fit a good UBEC (aka SBEC or Switchmode Regulator fixed at 5.5v to best of all results.
4A BEC is minimum for sports Nitro/GP models but when weight is not a problem, 10A is best overall.
. CC BEC Switching Regulator
"ESC & BEC - Setup to prevent majority of all RF Problems, Brownouts & Crashes"
"Glitches & Jitter in Receiver, Servo & ESC - Causes and Cures"
"Servo - Alterations, Calculators, Databases, Leads, Repairs, Convert to an ESC or winch & FAQ."
below
Alan T.
MB, CANADA
Thunder use this link and plug in your servo's you are using. As long as your servo's are not rated for 4.8 VOLTS ONLY then no need for the reg's. In fact a 5 cell nicd/nimh will have more volts then the LiFeP04 pack. And contrary to what AT said I think most users are running their LiFeP04 packs straight to the Rx. I know I am and many others, including JC from this thread.
http://www.servodatabase.com/
As Buschbarber stated the JR 791 servo is rated for 4.8 volts only. See here. http://www.servodatabase.com/servo/jr/791 You can see it shows 4.8 volt specs only.
This servo ( http://www.servodatabase.com/servo/futaba/s3001 ) is good for both 4.8 and 6.0 volts so if it can handle the 7.2 volts off a freshly charged nimh it can handle the 6.6 from a life pack.
So as long as your servo's are rated for 6.0 volts your good to go as is. If not then you could use a reg. or do what more of us are doing and use a diode to drop the voltage. Reg's can fail but diode's are much less prone to it.
ORIGINAL: Mikecam
Good reading:
. Voltage Regulators and LiFe Battery Packs ***
. Battery (Receiver packs) . LiFePO (aka A123 & LiFe)
. Battery (Receiver packs) . LiFePO (aka A123 & LiFe) - Alert re False Labels & excess voltage
. Servo - Burnout. Cause & Prevention
Alan T.
