Futaba 8UAF
Banned
Futaba 8UAF
Once upon a time:-))))))))))))
I had a set of instructions on how to resolve the problem cause by trying to program two switches to do the same function, and causing the dreaded "throttle cut" lock up that the 8U was notorious for. It used the Compac module socket, and "something" to fix this.
My son did this, and I am trying to recover his transmitter. HELP Please
Les
Les
RE: Futaba 8UAF
If the answer to your problem is not forthcoming from this section of the forum I suggest that you transfer your post to the manufacturers section where a Futaba rep like Bax or Krista will respond. Best of luck.
RE: Futaba 8UAF
Go to the top of this page and click on the RC Radios, Transmitters, Receivers etc link and it will take you to the cover page and in the first box click on Futaba Radios Direct Support and it will take you to the page to place you post.
RE: Futaba 8UAF
ORIGINAL: LesUyeda Once upon a time:-))))))))))))
My son did this, and I am trying to recover his transmitter. HELP Please Les
Radio System FAQ
Q. When I turn on my radio, I get a warning which says (throttle cut, idle down, snap roll, air brake, butterfly, inverted, throttle hold, or idle up).I've tried moving every switch on the radio, and I can change the error but not get rid of it. I cannot operate my radio. What do I do?
A. The 8U family of radios has a safety feature which will not allow you to attempt to start your model in any of these 'non-base' set ups for safety reasons.
Unfortunately, from what you describe, you have accidentally programmed two or more of these features to the same switch,
so that no matter what position that switch is in, one of these mixers is active and so you cannot operate the radio.
This is a programming error that is a very important one to avoid for the obvious reason that it makes your radio inoperable and if it did not make your radio
inoperable it would make your model potentially unsafe to operate.
8U non-super owners: Unfortunately, there is no override to get past this user set up error in the 8U.
You will need to send your radio for service so the Futaba service team can override this error.
The service team will also turn off the offending features or, if they cannot easily do so, then will blank the model's memory so that your radio will be operable again.
Please follow our instructions to send your radio in for service and be sure to make a note of your error so you don't accidentally recreate the problem.
8U Super owners: The 8U Super includes an override to get around this programming error. Simply press the +/- keys simultaneously.
This will temporarily override the error; however, for the safety of yourself, your model, and others, PLEASE immediately access the programming and fix the error.
Back to main FAQ/Contact Info pageMuch more information available below
"Radio Systems, Accessories, Alterations and FAQ" at
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
Banned
RE: Futaba 8UAF
A.T.
Thanks, that is about what I expected, BUT,
Somewhere, sometime, I remember reading about using a clone Compac module, and connecting several pins together to achieve the same thing. I have NOT been happy with sending my radio in for repair in the past, and and QUITE reluctant to do so.
Les
Les
RE: Futaba 8UAF
Have you ever tried Radio South for non warranty radio repairs or service. I have been doing so for years and have always been more than satisfied with their work plus the head honcho Tony Stillman is a very nice person to deal with.
RE: Futaba 8UAF
