Futaba Cross Trim
Futaba Cross Trim
I just changed my 9Z transmitter from the default cross trims to the conventional regular trim position to be compatible with my 10CAG. How do I make the throttle trim effective at low throttle and the elevator trim effective across its full range? That did not change when I changed from cross trim. Dan
RE: Futaba Cross Trim
ORIGINAL: All Day Dan
