airtronics receiver crystals
Old 05-20-2013, 06:45 PM
JDIFLYRC
Default airtronics receiver crystals
Hello,
I'm in need of airtronics ch 18 receiver crystals. I was given 4 dual conversion receivers and if I can find crystals for them, it would let me max out my rd8000 transmitter.
I've searched high and low. I found some made by performance devises that were said to be for airtronics. But I would rather have airtronics brand. Has anyone had any experience with the aftermarket ones? I would be grateful if someone could help me out
Thanks in advance
J D Parsley
Old 05-20-2013, 07:48 PM
A.T.
Default RE: airtronics receiver crystals
ORIGINAL: JDIFLYRC
Hello, I'm in need of airtronics ch 18 receiver crystals.
I've searched high and low. I found some made by precision devises that were said to be for airtronics.
would be grateful if someone could help me out Thanks in advance J D Parsley
Most aftermarket crystals are the same if not better, provided they are labelled as Sanwa compatible.
(Airtronics is more commonly known as Sanwa on the internaional market)
The GWS chart will help:
. Crystal compatibility between brands
Much more information available under sub section:
.Crystals, Oscillators & Piezo
below
"Radio Systems, Accessories, Alterations and FAQ" at
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
Old 05-21-2013, 09:11 AM
carrellh
carrellh's Avatar
Most US distributors have stopped ordering crystals so they are not easy to find. Hobby People does not have your channel in stock.
You can ask about them here: http://www.radicalrc.com/rrcxtalexchange.html - They do sell some directly versus requiring a trade
Old 05-23-2013, 07:03 PM
JDIFLYRC
Thanks for the response. I ordered four crystals made by performance devises. Gonna compare max range with antenna collapsed against genuine airtronics crystals with engines running. I figure if I can at least get same range, I should be ok.
Take care and again thanks.
JD
Old 05-23-2013, 10:20 PM
EloyM
My Feedback: (194)
I have a suppy of Airtronics crystals, though very few on the low end of the band (Sorry no 18's), but
good variety on the top channels. I find most Airtroncs systems don't require tuning if moving just a
few channel away, but of course a good comparative antenna down range test is a must.
