Help with programming 12x
My Feedback: (36)
MA
I have a JR 12x and am trying to set up a Jet with the rudder as master and nose steering (AUX2) as slave. I have the AUX2 disabled in the Devices menu and slaved to the RUDD in the wing type menu. So far so goood. Now what I want to do is disable the nose steering when the gear is up. When I try to set up a mix I can select RUDD as the first mix channel but can not selece AUX2 as the second mix channel as it does not show up on the menu. Any suggestions would be greatly appreciated.
Mark
Mark
