Hidden menu for FUT 9Z
I 've heard about hidden menu on Futaba 9Z that if you pressed two bottons simultaneously ( don't know which one ?), you could get in to hidden menu mode. Any Futaba Gig out there ?
regards
regards
No I do not know of anyway that you can press keys to get to the service menu. You have to get a special module that you put in the campac slot on the radio. For more info see http://www.soft.net.uk/orange/produc...er/enabler.htm and
http://www.soft.net.uk/orange/info/s...u/servmenu.htm
This is their main page http://www.model-gadgets.com/
If you want to get a service menu enabler I would recommend you get the 128Kbit UltraPAC which has two campacs and a service menu enabler all in one
There is actually a screen you can access pressing two buttons at the same time but there is nothing usefull there. All usufull functions are in the service menu.
Go to the voltmeter screen and press [L] and [M] simultaneously. Once the first message appears you may press [L] and [M] again which brings a second message up.
