FrSky TFR8 SB 8ch 2.4Ghz S.BUS Receiver FASST Compatible - Is the Range same as Futab
CA
I was checking out this new receiver -
that Hobby King is selling for $38 that has a S-Bus system and wondered if the Range was good for a 1/4 Scale Extra with a 50cc motor and as good as the Futaba receivers.
I have an older Futaba 6014FS 14ch receiver that went bad and need to replace it, I only have Futaba 7 channel receivers and need 8 channels.
The Futaba has been known to go 3 miles in FPV flying (good enough range) but one guy said he only got .4 of a mile or 6000m with this receiver.
Could he have got a bad one as this is way less than the Futaba receiver range. Has anyone used this receiver the description sais it is as good as the Futaba receiver.
http://www.hobbyking.com/hobbyking/s...ompatible.html
Also has anyone checked out the range on the Orange RX FAAST 8CH receivers. I use them they work great and I think they are manufactured by FrSky, but I have never put them up against the futaba receivers for range. I use them in Park Flyers and a 30 Raptor heli.
Futaba service want's $30 just to check the 6014FS if these receivers are the same why not just get one instead for only the diagnostic fee.
I use several of these receivers in Helicopters and EDF jets for over 2 years now and they have worked perfectly.
I range test every receiver I own before use and the Orange RXs have equal range to the genuine Futaba Receivers.
Two vids here of my own range checks - the first is with the Orange RX and the second is with a Genuine Futaba.
The HK website lists the range as 1.5 Km + From my experience they will work at more than double that distance easily.
http://www.youtube.com/watch?v=PPIWgfgvxAU http://www.youtube.com/watch?v=KVIR0a9s8TE If you do decide to use them make sure you follow the advice in the manual and:
1. Disable Fail safe in your Transmitter.
2. Only use High Speed mode if you are using Digital Servos.
Here is one in action in a small EDF..
http://www.youtube.com/watch?v=ruiuZahglQk
CA
These are EP models but can this receiver work for bigger 50cc models with no problems. Also has anyone tried these receivers up against Futaba using a FPV system where you fly with a camera as far as the signal strength will let you go. Your right .4 mile is around 6000 meters but the Futaba range is over 3 miles.
