Anyone using Tactic radios for big planes?
Just got back into hobby after 10 yr hiatus. Been flying 40 & 60 size planes with my OLD Futabas but needed more channels for my new project 89" Super Decathlon. Just got a Tactic TTX 650 - with a coupon - I got it & 2 recievers for $119.00 including shipping! As poor as I am I could not pass it up. I am building (& modifying) a Dynaflight Super Decathlon with lots of bells & whistles. Anybody out there flying a BIG plane with this radio? I am putting a lot of time & effort this plane.
I learned RC way back when there was no programming. For me and my flying, I do not need programming. However the Tatic 650 is rather easy to set up. I like it fine, but so do I like my other radios.
One thing that is very different is the battery pack set-up. It uses 4 alkaline AA for TX battery. I stopped at a home supply, bought one of those NMIH Energizer battery chargers for AA batts plus some NMIH cells. Relatively inexpensive. You can keep things working very well. I would never use alkalines in any RC.
I fly a big rendition of a 4-Star some 70" wingspan sport model and everything is working fine. I will be using my two for sport flying and such. These airplanes do not need more than 6 channels.
I bought the Tactic deal from Tower Hobbies with two receivers but had poor results with it. I could position the plane 100 meters from our concrete house and have no control of it. The receivers don't appear to be able to handle multi-path at all. Got a Spektrum system and no problems at all on three planes I have with Spectrum AR610 receivers in. The Spektrum stuff will cost you about 60 bucks more for the same number of receivers but well worth it for reliability. The Tactic stuff is fine for park flyers that are kept in close but I would never risk a larger plane with them.
My Feedback: (14)
IN
It's fine for about anything, but as with all the systems. You need the full range receivers, if you intend to fly full range. I've used it in a 60 size sport witoput any problems. and in about a dozen indoor models, no issues..
Tactic has recently released a dual-antenna receiver (TR625) that should prove more robust for installing in larger aircraft:
http://www.tacticrc.com/receivers/index.html
They specify that it is suitable for large glow and gasoline-powered aircraft.
ID
Thanks for the link. Just bought tx650 and two free 624 rxs. I'll get the 625 two antenna for glow models (those dang planes get far away, fast). I'll also use the tx650 for my flyzone micros.
