Dx6i transmitter
Dx6i transmitter
Why would you set the expo to INH? From what I read, it means there is no expo. The stick sensitivity always has a setting regardless if its at 0, -100% - +100% or INH.
Expo is a feature that takes the stick to servo movement from linear to non-linear. Not everyone likes expo so you can turn it on or turn it off.
If you understand expo, that should answer your question. If you don't, this article might help.
> Dual Rates and Exponential Explained
http://www.wattflyer.com/forums/vbgl...howentry&id=26
Expo makes the gimbals less sensitive around the center positions. As they are moved to a point beyond that area they become more sensitive. In other words the sticks become mushy as the expo is increased.
I am one who doesn't like it. On some large fast aerobatic planes I will add around 25% for the maiden flight and a few after and then start taking it back out as I get more comfortable with the plane. There are some planes like small extremely fast planes and wings and extreme 3D planes that can benefit from a little expo but I think it's better to learn to fly a "regular plane" with no expo.
This means your servo rotates directly according to stick response.
However, with a normal rotary servo, this actually is giving you a "reverse expo" response in your flight controls.
IE the controls are more sensitive near neutral due to the geometry of the pushrod to the servo arm.
As your servo rotates more the actual movement of the pushrod reduces for a given angle of rotation.
Setting 10-15% expo in your radio will compensate for this geometry and provide you with a true linear control response.
See this link for a better explanation
http://www.rcflightschool.com/SetupPDFs/Expo.pdf
On small Blade Helis I use Dual Rate of 115% on cyclic and 120% on rudder. This makes it much easier to flip them indoors.
