Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > RC Radios, Transmitters, Receivers, Servos, gyros
Reload this Page >
Do you think what's the most important when you choose a servo for your models?
Old 04-22-2014, 06:54 PM
michaelfan
Post Do you think what's the most important when you choose a servo for your models?
What is the most important factor when you choosing servos ?
1.Stall torque
2.Rating voltage
3.Motion speedWeight
4.Motor type
5.Gear type/material
6.Bearing type
7.Case material/color
8.Dead band width
9. Signal control mode
10.Overload protection
11.360°rotation
12.Work temperature/humidity
Or others you will consider.
Old 04-22-2014, 07:35 PM
ira d
Of course you want a servo that can do the job but the main thing is relliabllty.
Old 04-22-2014, 08:08 PM
woodie
woodie's Avatar
+1 on reliability
Woodie
Old 04-23-2014, 02:23 AM
A.T.
1.Stall torque
2.Rating voltage
4.Motor type
6.Bearing type
8.Dead band width
11.360°rotation
The most important thing is matching the servo to the job in hand.
No point in using a high spec servo in a cheap trainer nor a cheap servo in a high spec model.
Answers to your questions will be found under the following links:
. Servo - Buy Cheap Servo or save money by Paying More upfront.
. Hitec - Servo Configurator .. Use to find the best Hitec servos for your application.
. Servo - FAQ : Which servo to buy - Peak Servo Current Test Results.
Much more information available under sub sections
"Servo - Alterations, Calculators, Databases, Leads, Repairs, Convert to an ESC or winch & FAQ."
below
"Radio Systems, Accessories, Alterations and FAQ" at
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
Old 04-24-2014, 07:59 PM
michaelfan
Originally Posted by woodie View Post
+1 on reliability
Woodie
Actually the configuration has depend the reliability,right ?
Old 04-25-2014, 05:51 AM
woodie
woodie's Avatar
To me, reliability is how well all the components work together during the life of the servo. If any component fails, the entire servo fails. If I were to pick stall torque as most important from your list yet the servo arm breaks during a snap roll, reliability was still the most important factor.
Assuming the servo is 'reliable' in normal use, then my guess is you would get different answers from each pilot based on the demands of their particular aircraft. Pattern guys will be more interested in things like centering, gear lash due to the demands we have for precision, while guys that are into 3D type maneuvers might be more interested in torque/speed, stronger gears, etc.
From your list, I would probably pick 1, 3, 8 as the most important to me, assuming the servo is appropriate for the application I am using it in (pattern).
Woodie
Old 04-25-2014, 11:18 PM
Jetdesign
My Feedback: (8)
Jetdesign's Avatar
1) Reliability, first and foremost.
2) I also think about how the servo might be used in the future. I would rather spend a little extra and get 'more than enough' so I can use the servo somewhere else if need be. I hate having a new plane to put together and a bunch of servos laying around that aren't strong enough to use.
3) Reliability.
4) Accuracy.
Old 04-27-2014, 09:49 AM
K-Bob
I would first consider whether the manufacturer employs shills to spam public forums to promote their product under false pretenses.
Old 04-30-2014, 12:16 PM
dirtybird
To me the most important thing is the price.
They all have IC's,motors and gears made in the same place.
And I can check to see how well is assembled.
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
