HItech HS5645MG servos ???
Old 06-01-2014, 01:54 PM
warbird_1
My Feedback: (61)
warbird_1's Avatar
Default HItech HS5645MG servos ???
Anyone know of any ongoing issues with the HS-5645MG Hitech servos? i was told that there was some past issues . i bought 6 of them for my boomerang torus .. WB_1
Old 06-01-2014, 03:08 PM
A.T.
The HS-5645MG is now an older servo and no issues have been reported for a long time.
For peace of mind, always "age" servos as electronics fail early in life or last a very long time.
Work the servos on the bench or easiest to use a servo driver/tester for a period, the following may be of assistance:
. BURN IN - Aging of RC Transmitter, Receiver & Servo components quote
"<snip>
extract from attached copy of "BURN IN - Aging of RC components"
"Burn In" is the term used to identify the process of aging electronic components and systems.
This Burn In or aging process weeds out inferior components through their premature failure.
Due to the nature of semi conductor components such as transistors, diodes, and integrated circuits,
good components can last in excess of 40 years while, on the other hand, faulty components usually fail
soon after being put into operation. It is because of this early failure or infant mortality that a Burn In
period can increase system reliability and probably save you an airplane. "
however if buzzing remains persistent, following may assist:
. Servo - FAQ : Metal Gear Servos - DIY Repair & Extend MG Servo Gear Life
. Servo - Burnout. Cause & Prevention
. Servo - How to Diagnose Servo Failures & Repair Servo
much more information is available under sub sections:
"Glitches & Jitter in Receiver, Servo & ESC - Causes and Cures" &
"Servo - Alterations, Calculators, Databases, Leads, Repairs, Convert to an ESC or winch & FAQ."
below
"Radio Systems, Accessories, Alterations and FAQ" at
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
Old 06-01-2014, 03:30 PM
warbird_1
My Feedback: (61)
warbird_1's Avatar
A.T. i was going to plug each one into a match maker and let them cycle for awhile. what kind of time frame would be good ? WB_1
Old 06-01-2014, 07:16 PM
A.T.
5<20 minutes at medium speed, which represents a lot of time, is all I have bothered with.
Best wishes
Alan T..
Old 06-02-2014, 09:54 AM
Truckracer
My Feedback: (19)
warbird_1, the 5645 and 5625 servos are certainly reliable but frankly, do not center quite as well as most of the newer offerings. Like many products there were some problems way back when they were introduced and the problems were resolved but the deadband / resolution issue never really improved. There is quite a bit written about these servos in the various forums. I favor the analog versions of these servos as they are more precise and quite a bit cheaper.
Old 06-02-2014, 01:21 PM
warbird_1
My Feedback: (61)
warbird_1's Avatar
maybe i'll send them back. i searched for threads regarding these servos and didn't find anything. WB_1
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
