TacTic t-40 sevro
TacTic t-40 sevro
Has anyone used these servos in A gasser? The reason I ask is I bought two to use on my Gaint Stik for the elevator I am also using Dubro Duel control horns and Duel servo arms along with ball links 4-40. These are metal gear servos and when I hook them up and power them up they have about 1/8 play in them ( I can move the elevator by hand and watch the servo shaft and the servo arm move) I don't think this is normal for a new metal gear servo I know over time metal gear servos will develop some slop as the gears wear would you use them?
