Orange receiver broken?
Hello everyone,
I'm new to RC flying and am making myself a foam airplane from scratch.
The problem i'm running in to is that the throttle doesn't seem to work.
After some research i came to two conclusions.
1) i have to calibrate the esc to the full throttle position
2) my receiver doesn't work
What works?
All the servo's are working fine, When i replace the rudder with the motor the motor does work perfect only with the rudder control. So the motor isn't broken.
The transmitter also seems to do it propperly as it's showing that the throttle is on.
What not?
When i put a servo in the throttle port it does nothing when i try it. I read somewhere that this means that the throttle port on the receiver simply doesn't work. Could anyone verify this for me or am i missing something?
I'm using a:
R615X reviecer
t-six transmitter
Thanks for helping!
What works?
What not?
I'm using a:
R615X reviecer
t-six transmitter
Thanks for helping!
MI
You may only have to calibrate the receiver. Rebind your TX to the RX. Before you bind set your throttle trim all the way down.
If, when you did your last bind, the throttle trim was to high and the RX will not arm.
Hello everyone,
What works?
What not?
I'm using a:
R615X reviecer
t-six transmitter
Thanks for helping!
What works?
What not?
I'm using a:
R615X reviecer
t-six transmitter
Thanks for helping!
Also agree to try rebinding, if that doesn't work the receiver may be faulty. I have two of the R615X and they are not the best Orange receiver. There have been known bad batches.
Try something like an R800X, it is more expensive but works far better in my opinion.
Here are two vids of my own testing of the R615X (they failed my own personal standard so I don't use them)
Reboot times
https://www.youtube.com/watch?v=TmjLZ3MzrXA
Range testing
https://www.youtube.com/watch?v=cuTp2W7yQfc
GA
Another thing to try.........go into throttle sub trim,and set a plus or minis 20 on the throttle channel. My JR10xpro would not bind to any of my electric aircraft until this was done in sub trim. Called Horizon and they said the 2.4 mod in the transmitter was not at zero trim even though it showed 0 on the screen.......+ 20 on the sub trim allowed all 3 of my electric to come alive. Just a thought
Thank you all for helping,
it does have a control monitor showing i'm moving the throttle channel
Ive tried rebinding the receiver. Also with sub trim on the throttle with no result.
It seems the motor hasn't been calibrated yet. i only hear beeb tones with regular interval. It doesn't respond to setting the throttle all the way up or down when binding.
All the other servo's work perfectly. And i dit get the motor working like it should on the ruddr channel.
Is there a way to fix this receiver?
You have a defective receiver.
You eliminated pretty much all other possibilities.
According to your checking, the servo monitor screen shows the movement of the throttle stick, the motor/ESC work on another channel and a servo does also does work when plugged into the throttle channel on the receiver.
Do you have another receiver on hand to try???
Pete
Pete
My Feedback: (10)
Set the atv on the throttle to 120% on both the high and low end. This is most likely the problem. It sounds like the esc is never seeing a low throttle condition to arm. If it still doesn't arm then try reversing throttle channel. If itstill doesn't work, plug the esc into another open channel and put a servo on the throttle does the servo work? If it does then check to see that you don't have some sort of mix in play on the transmitter like a safety arm switch programmed. Odds are slim the receiver is defective if the other channels work. I have seen it but it is rare... Also. If the esc is beeping it IS seeing a signal from the receiver.. just not the signal it needs to arm...
My Feedback: (12)
WI
so when you plug a servo into the throttle port, it does nothing? I don't know your radio, does it have a throttle hold function?
If not, the rx is likely bad. Find another rx. bind it to your radio and see what it does.
Pete
Pete
It does come with a throttle inhibitor but ive tried that in the on and of position.
atv is regulated by adjusting the sub trim right?
i'll have another receiver ready by monday to try it.
Here's another thing to do while you're waiting on another receiver.
Create a new model in the radio where all settings are at default, then bind your receiver to that new model memory. I say to bind the receiver to the new model memory because I don't know if the Orange T-6 has the Spektrum Model Match feature. With model match you would have to re-bind the receiver to use it with a different model memory.
Using a different model memory will eliminate any problems caused by a mix affecting the throttle channel.
If I remember correctly, you did say that the servo monitor on the T-6 showed movement on the throttle channel. That's a reasonably good indicator that the problem is with the receiver and not the transmitter.
Have you flown any other planes with this radio, or is everything brand new?
Good luck,
Pete
Good luck,
Pete
