3-Axis Aircraft Gyro System
This gyro will work like the flybarless. You can set up elevator rudder and ailerons to act simultaneously. There are 3 modes off, normal and heading lock. I have not used yet but a friend has one and I have ordered one too. Sounds like it is going to be one of the best available. But it only works with DMSS XBUS System.
It is not that easy to make a gyro system resistant to gasser vibs and does not only rely on using the right gyro sensor, but putting way more intelligence into the firmware. A long experience with the heli systems helped a lot, but still most systems in the heli market do not work well on gassers, especially when making use of accelerometers. So this statement needs to be technically prooved. Surely we will know in some months.
I just wanted to point out, from the experience out of the heli sector, that this does not mean by default that any gyro would for sure work the same way on gassers, as this is the most difficult job to get done.
Sorry if I may have expressed this misleading or did not get your point correct.
