JR 28x software update wish list
Old 03-20-2015, 08:44 AM
Edbaker
My Feedback: (44)
Default JR 28x software update wish list
I figured it would be started eventually so here goes. Hopefully it will do some good
1 Have the ability to turn on icon text for icons on the home screen
2 On the monitor screen it would be nice to see a numeric value along with the bar graph
3 The ability to sort models in the model list in any order
4 If a menu screen has a sub menu, it should be indicated somewhere on the menu screen.
Old 03-20-2015, 06:08 PM
warbird_1
My Feedback: (61)
warbird_1's Avatar
i would like to see an Android based system restart/boot widget , more battery info widget options as well as more trim widget options
Old 03-22-2015, 07:41 AM
COL J
Boy I hope this just me, but I cannot figure out how to activate voice prompts for the timers. If it can't be, which I simply can't believe with this radio, then this is a Big- in my opinion. There is no way you are going to hear these little beeps with others flying. In the comfort your home, yuo can hear but not if anyone is talking. Thanks
Old 03-26-2015, 04:28 AM
gmccluskey
I am hoping with time, new widgets are developed. The stock ones are gimmicky and take up too much space (ie for the trim or Rx voltage). I would prefer just numbers for the voltage and simple indicators (like the 12X for trim)
Old 04-05-2015, 04:12 AM
Edbaker
My Feedback: (44)
Please fix issue with travel adjust screen Doesn't display the proper channel if you reconfigure the channel assignment
It would be nice to have the ability to name channels ie call a channel the brake channel instead of aux 10 It can get confusing when you have many channels
When you tap on the flight mode widget it would appear that you should have the ability to turn on and off certain voice prompts This doesn't seem to work and there is nothing in the manual about how it should work
Old 04-10-2015, 04:34 AM
Airman98
My Feedback: (8)
Airman98's Avatar
http://www.jrpropo.co.jp/jpn/dl/details.php?hen=d0398
Looks like the first update is out.
Old 04-10-2015, 07:35 AM
Don McCullough
Receiver per antenna packet/frame loss (e.g. Spektrum) or RSSI signal strength (e.g. Jeti) telemetry with settable threshold alarms.
Old 04-10-2015, 08:30 AM
Edbaker
My Feedback: (44)
+1
Old 04-18-2015, 04:04 PM
bjw4072
Default Timer reset
I have set switch 'B' as a momentary switch, one way to start a timer, and other way to stop timer.
However the only way to reset a timer is entering a sub-menu on a screen via finger pushing ....
that is not satisfactory on the flight-line in sunshine.
There needs to be a way to reset a timer via a momentary switch.
Old 04-19-2015, 05:19 PM
newshoundaussie
Anyone have a problem connecting to internet. No signal to provider sitting next to modem. Everybody else on street signal strong.
Old 05-03-2015, 06:02 PM
bjw4072
There is a software error that needs correcting.
Go to Other-Gallery-Albums
Then at top right of screen there is a camera icon.
If you click on that icon the entire screen inverts and everything locks up.
The solution is to re-boot by turning off power switch, plug in charger for a few seconds,
remove charger, and turn on power switch again.
There does no seem to be any reason for the camera icon to be there.
This is not normally a problem for usual operations and is a minor issue.
Old 08-23-2015, 08:51 PM
chorner
Gear sequencer having a much larger than 10 second main timeline limit
Old 10-10-2015, 10:13 PM
rossmick
rossmick's Avatar
bjw7042
I second the problem with selecting the camera icon. First place, there is no camera, and second, it is a sure way to lock up the radio. Please remove the icon and the code that goes with it.
While I and at it, please rewrite the code that is used for voice messages. Much less expensive radios have this figured out and it does not see that difficult a problem to solve.
