Dynam radios
Old 06-18-2015, 08:13 AM
skylane42
My Feedback: (53)
Default Dynam radios
Any one know how to range check the Dynam radios? They don`t have a bind button, they rebind each time they are turned on. On my Spectrum I know you depress the bind button to range check.
Old 06-19-2015, 08:29 PM
coriolan
coriolan's Avatar
There is a pdf manual on their site, doesn't seems to have range check button:
http://www.dynam-rc.com/products/tra...r/2.4G-6ch.htm
Old 06-21-2015, 07:25 AM
skylane42
My Feedback: (53)
Note: On the Rx, there is an EXTENT dial. This dial affects the travel limits of the CCPM servos (Aileron,Pitch, Elevator). The default is 50% (in the middle. If you wish to check this, move it fully CCW, note the position, then fully CW, note the position, then move it half way.
Thanks Mike
Also in case some one else is checking.. I have a 4 Channel Tx... the switch on the top left is the motor safety switch. You have to hook up your radio and receiver and let them bind. Then pull the switch forward and then back to are the Throttle. The rotary knob on the top face is Expo control.
skipper0802 (05-14-2022)
Old 04-30-2022, 07:10 AM
skipper0802
Question Unknown Switch Function Inside Tx?
Hi All,
Inside my Tx, there's a two-position slide switch underneath the center circuit board. I don't know what purpose it serves. Maybe it provides the mode 1 or mode 2 choice, factory reset? Does anyone know for certain?
TIA,
Eric
PS: I had two pics to add but as I don't have 10 posts yet I'm not permitted to post URLs :-( I can PM the pics if someone is interested.)
Old 05-14-2022, 06:50 AM
skipper0802
Hello skylane,
Thanks for posting this I noticed this trimmer on the Rx and wondered which "extents" it was intended for... there's nothing in the user manual about it. My question: does this trimmer setting affect:
  1. all servos connected
  2. cyclic servos only
  3. tail rotor servo
Cheers/TIA
