8FG SUPER talking to several receivers at the same time
BC, CANADA
I only found out about this issue because after all these years /I was field servicing two planes at the same time. I left the battery connected ( yes, I know ) on my YAK which has a 66106HFC receiver while I prepared another plan for flight ENIGMA which had a
R 617FS receiver. The transmitter was set to the correct model and I found both plane's control surfaces operated at the same time. Fortunately both planes had throttle lock set to the same switch. The are no other flyers using Futaba at the field I was at so maybe that was a good thing.
Got it home and on further investigation found that the same thing happened to three other planes sporting another 3 R6106 HFC. I have a R6008SB that was unresponsive in another plane. And the smallerR6106HF partially responded.
My understanding, obviously wrong, is that each plane setting on the Transmitter links to the corresponding receiver with a secure digital signal.
This could turn out to be a serious issue while flying although nothing ugly has happened yet with up to 20 other flyers at a field on any given day.
Any pointers would be appreciated
I've often wondered why Futaba never adopted their own version of a model matching system ? I wonder if it's "owned intellectual property" and can only be used under paid license ? Since Spektrum copied SBus from Futaba I think it'd be OK for Futaba to copy Spektrum's "Model Match" as this day to day safety enhancement sounds far more important to me than whether all data goes down one wire or many (the basis of SBus) .....
BC, CANADA
I guess I have just been lucky having not run into this scenario before. Most of my issues are the usual brain to hand problems. I do like the transmitter even though the programing learning curve was initially a tad steep. Mostly translation!!
Thanks for input. I feel a bit safer now. I will let the flyers that ran for cover know.
A funny side story ;
My first 2,4 GHZ radio was the 6EX2.4 and it had what was referred to as the "Zero GUID" malfunction in manufacturing . Your radio , which is operating normally , will NOT control any other radio not bound to it due to it's "Globally Unique IDentification system" numbers . An RX must have the same number sequence as your TX , which is done at the time of Binding . The TX's GUID gets stored in the RX as the only one it'll accept commands from . Well , a bunch of TXes got out of the factory with their GUIDs programed to "0000000" . And , with no unique number , just zeros for every character , ANY RX programmed to a Zero GUID TX was operated , and yes this does mean it would control other people's models if they too were zero GUID !!!! I think there were a few crashes at large RC flying events and that's how it was found . My TX ended up getting sent in and reprogrammed with a proper GUID for free under warranty and luckily I never shot anyone down cause I was the first and only one at my field with the "newfangled" 2.4 .
BC, CANADA
My first Futaba was also the 6E and no, I did not shoot anyone down except in full contact combat. Thanks for input. I will breath a bit easier now. Still odd that a couple of the receivers did not respond at all.
This is my usual fleet that I fly right now. I enjoy the variety.
Nice looking fleet !
I fly pretty much the same kinds of planes , Everything but the flying wings . Got nothing against em , love to watch others fly em , I just have a real hard time telling which end is which once they get a good distance away from me . With a big ol tail I can always keep track of which way it's going
BC, CANADA
Looks like you are flying a gas/electric mix; good deal; I had nitro years back; when I started up again I was travelling around for 6 months/year in a motorhome and just didn't want to hassle of the fuel and mess. Got back into it in about 2006-2007 and like an idiot, bought a Parkzone Stryker C ( if my date is correct ). That was a mistake. I like flying slow stuff sometimes, and I have a need for speed controlled by my wallet. The Parkzone Spitfire got up to 79MPH and the Stryker hit 119 MPH. I use the Eagle Tree Airspeed unit which is accurate enough. Too much money I think for me to push them any farther. I am now working on a "Never Flown" Parkzone Spitfire; taking it right apart, adding carbon fibre, replacing hinges with pin-hinges and I am going to paint it up more racy like the voodoo. I am leaning towards an orange base color.
The PZ Spitfire sounds like a great project , I like to personalize my ARFs as much as possible too , it makes them more "ours" rather than looking like every other one does . Biggest thing is I remove all the stickers that come with them for a much cleaner look . I do still run some engine powered as you noticed in my photos , but out of an honest 40 model airplanes I own , 15 are fuel powered (either Gasoline or Glow) with the other 25 being electric The electrics really lend themselves to "grab and go" flying at a moment's notice VS the fuel powered which can only be flown at certain fields which aren't as close as my local schoolyard . The half hour cleanup of glow slime is another huge factor in my electric flying preference , even though I grew up flying engine powered . Yea , in my youth electric was a dream , a dream I chased with control line planes having the lines carrying the power and a small car battery in a camping backpack for power . Thank God for LIPOs
