New to rc...need some help with Grasshopper.
I recently bought a Tamiya Grasshopper that has a Tamiya stock 380 -S Motor. I have a Futaba 2DR AM R162JE - 27/75MHz Transmitter. It has two S3003 Standard Servos with two X-Shaped Arms, FUTM0031.
I now need a speed controller. I don't know how many turns the Tamiya 380 -S Motor has, so I don't know what to get. Will the Futaba MC230CR work with this configuration? If not, do you have one to recommend? Would the Tamiya TEU-105BK be a better choice?
Secondly, I am considering getting a Tamiya 380 Sport-Tuned Motor for my Tamiya Grasshopper. I read that it is a 29 turn motor. I have the Futaba 2DR AM R162JE - 27/75MHz Transmitter. It has two S3003 Standard Servos with two X-Shaped Arms, FUTM0031.
What Futaba speed controller would work with that configuration? I read that the Futaba MC230CR operates motors that are 20 turns up to 27 turns. This Tamiya 380 Sport-Tuned Motors has 29 turns.Will the Futaba MC230CR work with this configuration? If not, do you have one to recommend? Again, would the TEU-105BK esc be a better choice?
