futuba 2.4 won't power up.
Old 08-09-2015, 07:52 AM
JohnQ1962
My Feedback: (24)
Default futuba 2.4 won't power up.
It's been sitting for nearly a year, is there fuse inside ?
Old 08-09-2015, 08:06 AM
woodie
woodie's Avatar
Not sure what part you are referring to. Transmitter, receiver, configuration, etc?
Woodie
Old 08-09-2015, 09:44 AM
Rodney
If you are talking about the xmtr, did you leave the battery connected while it was stored? If so, and it was a NiCad battery, check the wiring between the battery and the switch for corrosion. If a NiCad went bad, you could have black wire disease (yes that is a true problem). If one of the wires is corroded, stiff and won't solder, you have it. If so, the only solution is to replace the wire effected, it usually only progresses to the first terminal past the battery.
Old 08-09-2015, 12:36 PM
JohnQ1962
My Feedback: (24)
Thanks , that's the problem. Much appreciated. Take care maybe some day I can return the favor .
