receiver help
Old 08-10-2015, 12:20 PM
thenewguy101
Default receiver help
I found this receiver http://hobbyking.com/hobbyking/store..._Receiver.html and I was wondering if it would bind with the PKZ3341 transmitter. I didn't order them yet, also does a receiver needs to be fcc approved because I am not sure if this is
Old 08-10-2015, 03:50 PM
grotto2
grotto2's Avatar
newguy-
If you go to the hobbyking URL and look down at the bottom, there's a discussion area you can log into and ask your question. That might improve your odds of getting a good answer.
Old 08-15-2015, 06:02 PM
coriolan
coriolan's Avatar
It will bind since it is DSM2/DSMX but the PKZ3341 is a low power transmitter intended for small BNF(it doesn't have much range and very basic)
http://www.parkzone.com/Products/Def...ProdID=PKZ3341
Only transmitters need to be FCC compliant!
Old 08-16-2015, 02:12 PM
thenewguy101
So what is the range i was going to fly it across the east river at the shortest point
Old 08-16-2015, 03:17 PM
JohnBuckner
JohnBuckner's Avatar
You are not going to get a hard answer as they do not exist and certainly not from the manufacturer but the first clue, comes from the first statement in the link you posted "perfect for small foamies and indoor models" I would be amazed if any of that stuff reached 200 feet I have seen often far less than that.
So just how far across are you talking about at the east river and are you talking about flying something farther than you can see???
John
Old 08-16-2015, 08:21 PM
thenewguy101
I am building a small foamie, and I will not fly this farther then I can see, planning on flying between the triboro and the hell gate bridge, before I reach the other side of the river I will bring the airplane back
Old 08-16-2015, 08:25 PM
thenewguy101
This is the plane that I will fly http://www.rcgroups.com/forums/showp...&postcount=294
Old 08-16-2015, 08:40 PM
thenewguy101
That black car you see on the left is where I will be with the transmitter http://wirednewyork.com/images/bridg...ugh_7apr02.jpg
Old 08-17-2015, 02:28 AM
Steve Percifield
My Feedback: (14)
Steve Percifield's Avatar
Yes , the receiver should work with the transmitter. And No, it probably won't have that range. It is not even a park flyer transmitter. It is intended for indoor, or very close in flying.
Old 08-17-2015, 07:37 PM
coriolan
coriolan's Avatar
Did you check this Rx manual?
http://www.hobbyking.com/hobbyking/s...X893272X48.pdf
You should test it over land first to determine the maximum range, Good luck!
Old 08-17-2015, 08:28 PM
thenewguy101
So how range is determined
Old 08-18-2015, 06:54 AM
JohnBuckner
So that is the whole point it is not! At least in hard well defined numbers as I noted in post #5 and certainly no manufacturer would publish those kind of hard numbers.
What you want to do is unrealistic. First there is no way I would go beyond perhaps forty feet or so with the transmitter you have and the receiver you linked. The picture you linked is a good four hundred feet or so. Now the quite small airplane you linked is pretty cool however at that distance there is no way you would even be able to visually control it. Learning how to fly is what everyone leaves out of the equation but nonetheless doing it over water with a landplane is a really, really bad idea.
John
Old 08-18-2015, 08:41 AM
thenewguy101
Alright so would this be good for flying on a soccer field with snow because me and my friend are planning to fly it in the winter
Old 08-18-2015, 08:51 AM
JohnBuckner
Yes that would work. As always best you buddy up with some one who has some experience.
John
Old 08-18-2015, 08:53 AM
thenewguy101
https://m.youtube.com/watch?v=ZY35gWLb0gM this person had used the pkz3341 transmitter
Old 08-18-2015, 09:05 AM
thenewguy101
Me and my friend are making plans for a rc spruce goose that's made of foam might have a 60 or 70 inch wingspan with 4 channel control so what transmitter would be great for flights that can go across the river and back
Old 08-18-2015, 09:07 AM
thenewguy101
We are planning to complete this by next year and we'll try to post the plans somewhere
Old 08-18-2015, 04:46 PM
[email protected]
buy a good radio and receiver and not from hobby king
