Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > RC Radios, Transmitters, Receivers, Servos, gyros
Reload this Page >
Need help to change 2.4ghz Super Micro System linear servos
Old 12-29-2015, 07:15 PM
BoiseBee
Default Need help to change 2.4ghz Super Micro System linear servos
I may not be in the right area for this type of RX and servos. I'm new to UM micro RC. (Converting SIG Parasol FF rubber to RC). I'm using a DX5 TX. Two linear servos on the RX brick operate Elevator and Rudder (mode 2). Rudder is on left hand stick, Elev on right stick.
DX5 doesn't indicate any capability to switch servos. Is there some way I can modify the linear servos (2.4ghz Super Micro System linear servos (HK) so that the Rudder will work on right stick?
Thanks for any help, ideas, or sympathy.
Old 12-30-2015, 11:42 AM
dirtybird
Turn the transmitter upside down
Old 12-30-2015, 05:02 PM
coriolan
coriolan's Avatar
This pdf explains how to program this Rx for rudder/elevator on the right stick,also V-tail & Elevon:
http://www.hobbyking.com/hobbyking/s...X103718X37.pdf
http://www.hobbyking.com/hobbyking/s...5X103718X6.pdf
For most HK products you can access manual by clicking on the "Files" tab:
http://www.hobbyking.com/hobbyking/store/__56167__2_4Ghz_SuperMicro_Systems_DSM2_Compatible _Receiver_w_Brushed_ESC_Linear_Servos.html
Old 12-30-2015, 06:20 PM
coriolan
coriolan's Avatar
The OP needs rudder&elevator on the right stick, which isn't possible with the DX5 he is using!
