Need help with mix on SkyFky i6 Tx
I'm a novice and need some help on setting my mix on the Tx. but my i6 manual is written for someone with experience.
OBJECT: When my throttle is increased, I would like to give the plane a bit of DOWN elevator. It has the following settings:
MASTER - I set it for CH3 (throttle)
SLAVE - I set it for CH2 (elevator)
POS MIX
NEG Mix
OFFSET
What do each of the last 3 settings do?
Thanks for any help in advance.
POS MIX
NEG Mix
OFFSET
