Orange GA7003XS Fasst compatible GYRO Rx
Old 07-06-2016, 04:48 AM
davidej
Default Orange GA7003XS Fasst compatible GYRO Rx
I have just bought a couple of these from Hobby King . AFAIK Futaba do not do anything comparable.
I fitted one in a plane and am having trouble setting it up - the instructions leave a bit to be desired.
It is in a regular power plane with aileron servos via a Y lead - no flaps, v tail or other complications.
At first it seemed to work OK with the little switches and and pots as received. I could even turn the gyro action on and off with CH5. However the stabilisation action seemed to be the wrong way- I thought that would be simple to correct by rotating the appropriate pot into the negative sector. This didn't seem to make any difference.
So I thought maybe the little switches were in the wrong position - as I said, the instructions were not very clear. So I tried them in the opposite direction. Now everything seemed dead, The servos don't even respond to the sticks, let alone gyro action.
I put the switches back as found but still dead. It is not the transmitter as I have tried with a conventional Rx. The Orange one is still showing the green LED to show it is bound.
As an extra checks, firstly,I bound the other orange Rx I had bought (not touching any of the pots/ switches) and that seemed dead also. Then I bound it to another FASST transmitter and is was still dead
I don't think the new Rx's are faulty, I just think I have done something stupid - but cannot work out what !
Old 07-07-2016, 01:09 PM
davidej
I managed to get a HobbyKing product specialist online and he sorted out most of my problems..
The three little 'mode' switches should all be over to the left.. The "manual" as HK flatteringly call it, seemed to me to show them to the right where nothing worked. To complicate matters, one of the Rx's was supplied in this conditions so it seemed dead from the start.
The second problem was trying to change the direction of the 'kick'. I had overlooked the instruction that the Rx has to be turned off and on again for any change in the pot (or switch) position to take effect.
I am just left wondering if I can run two aileron servos on separate channels. As far as I can make out from the manual, I should be able to do so, but I don't know on what channel for the second servo. The HK advisor signed off before I could ask him!
Old 07-08-2016, 06:30 AM
do_hickey
yes i have one set up with two ailerons, the top dip switch needs to be moved to the right.
Old 07-08-2016, 07:29 AM
davidej
yes thanks -that works with the second servo on ch6
Hope we get some better weather here to try it - it looks a good bit of kit for only about 30 bucks
Old 08-27-2016, 08:12 AM
RCPilot100
Any update on how this unit performs? I just got one yesterday and yes, the instructions are terrible. From what I've learned online, channel 5 turns the gyro function on / off - nowhere is that mentioned in their instructions. My Futaba 12Z sets up channels 5 and 6 for dual servos. So how does that work?
Old 09-02-2017, 04:56 AM
Howiex
Default GA700xs
what if you want to fly a 4 channel plane, will this not work for gyro mode? Having trouble moving dip switches. I have no mixing or vtail where should the switches be? Thanks.
