Tatic Tx antenna question
My Feedback: (53)
Hi, I have a Wildcat that came with a Tactic radio. I can`t get a good range check on the radio. I found the TX antenna wire damaged. Can you tell me what kind of wire I can use to replace the current one? Also the old antenna wire has a bullet looking anchor on the top that goes into the top part of the antenna, is that critical to have on a new antenna? I have some old antenna wire that was used on the old 72mhz radios, will that work?
Bill
Bill
