DX9 with 4 flap servos
Old 01-04-2017, 06:45 PM
p3arljam
Default DX9 with 4 flap servos
I have tried everything i could think of and still no luck here is my setup and what i am trying to do. I have a DX9 with a AR7350 RX and the plane i have has 4 flap servos 2 per wing. On both wings i have the flaps servos Y harnessed together and each is plugged into separate channels (6 and 7) . I have the mix setup as follows FLP/AUX2 . In the flap menu i have it set to a 3 position switch (B) .The first position is set to 0% (no flaps) second position 35%(half flaps) third position70%(full flaps). I set the servo speed to 2.0 seconds for a slow deploying of the flaps. When i deploy the flaps one side works as it should the other side does nothing when i move to half flaps and when i move to full flaps it goes all the way down but much faster then the other side. Any help would be appreciated.
Old 01-04-2017, 08:38 PM
Zeeb
My Feedback: (41)
Zeeb's Avatar
Sorry but it's late here and I cannot figure out why you are messing around with Y-harnesses on a 7 channel rx when you have a really nice 9 channel tx?
First thing I'd do is get a nine channel rx and simplify your life/setup.....
Old 01-04-2017, 08:45 PM
p3arljam
Actually that would be adding 2 more channels to the mix problem I already have. I want the 2 flap channels working as one and having 4 flap channels trying to work as one does not sound easier in my opinion.
Old 01-05-2017, 09:14 AM
Zeeb
My Feedback: (41)
Zeeb's Avatar
Well okay, sounds like you have the situation under control and don't need any help.
Old 01-05-2017, 09:25 AM
p3arljam
Actually I still need help but having four separate flap channels isn't the issue it's why the two flap channels I already have won't work together. I have already paid for my 7 channel Rx so buying a 9 channel is not an option at the moment.
Old 01-06-2017, 06:14 AM
DP01
DP01's Avatar
In system setup, go to Aircraft type, change the Wing to 2 Ail 2 Flap. This will assign LFL to CH5 and RFL to CH7 automatically.
No need for mix!
Old 01-06-2017, 07:21 AM
p3arljam
No need for mix!
Thanks for the response the issue was i am using a 7 channel AS3X RX which is programmed by connecting your RX to a PC program and the wing type is set in the PC program and the wing type in the TX is suppose to stay at default . After two days of trying to get it to work i started over . I was still having the same issue but i decided to change the wing type in the PC program and in the TX (1 AIL 2 FLAPS) and still had the issue. At that time i just took a break turned off the TX and PC and worked on my engine. I came back after a few hours turned the TX and plane on and it was working dont ask me how because i made no changes from the time i took a break.
