Soldering wires
Is it okay to solder copper rc wire to a max6 esc which has silver wire,,will it solder ok or do I need the same type wire for it to solder well... thanks guys....
You should be able to solder that wire to your ESC but you want to be sure to use a 60/40 type solder with rosin core!
It also depends on what type of solder iron that are you using to solder with. I have a 40 watt ungar which is out of business and I also have a 65 watt Hakkio which is one of the best out there!
good luck
Michael
good luck
Michael
